Old 07-22-2012, 01:39 PM   #57
Ray@Carsmo
thanks for the writeup!
Ray@Carsmo is offline   Reply With Quote
Old 07-23-2012, 04:58 PM   #58
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
So, I just had my car in service and had them check out why my power mirrors stopped working... Apparently, if you disconnect the DRL resistor - as described in this thread - you will also lose your power mirrors. I will live with it until my new ECM arrives that can program the DRL's to be turned off.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 07-24-2012, 07:42 PM   #59
roddy
roddy's Avatar
Drives: '13 Ultramarine
I think your dealer may be feeding you a load of poo... I did the DRL delete as instructed about 3 weeks ago. When I went out to the car this morning, first thing I did was check to see if the mirrors were still working. They work fine.
Old 07-24-2012, 08:12 PM   #60
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
Originally Posted by FRSpdDmn View Post
So, I just had my car in service and had them check out why my power mirrors stopped working... Apparently, if you disconnect the DRL relay - as described in this thread - you will also lose your power mirrors. I will live with it until my new ECM arrives that can program the DRL's to be turned off.
Removing the relay is not instructed.
Removing the Relay is not the way to go. Remove the Resistor as instructed in the first post.
Ishii
Ishii Motors is offline   Reply With Quote
Old 07-24-2012, 10:48 PM   #61
roddy
roddy's Avatar
I misread. I thought FRSpdDmn meant the resistor. I did not remove a relay.
Old 07-25-2012, 12:09 AM   #62
FRSpdDmn
Ishii
Sorry, I did mean RESISTOR. I will fix my post. Unplugging the resistor will kill your power mirrors (according to my dealer, that's why my power mirrors are not working).
-Anthony
Old 07-25-2012, 12:11 AM   #63
FRSpdDmn
Out of curiosity, is your car one of the early ones that is eligible for the DRL ECM replacement?
-Anthony
Old 07-25-2012, 06:38 AM   #64
roddy
roddy's Avatar
I'm not sure... It is # 2955, built in April. Manufacturers have been required to have DRLs on their cars here since 1990 or so. even if I could get the updated ECM, I doubt my dealer would shut them off. Since removing the resistor, I drive with my running (parking) lights on so there is some sort of light showing at the front. I think this looks much better than DRLs, and many other sporty cars use the marker lights as DRLs anyway.
Old 07-31-2012, 12:43 PM   #65
reeves
Originally Posted by markmatley View Post
Its so awesome when the parking brake is down, the DRL pops on! Pull up the brake, the lights go off! *thumbsup*
For those who hate it, but MUST have it for legal reasons.. Maybe this is a better way to disable the DRL? Could you make a foglight-type switch and hook it up to the E-brake wire that runs to the DRL? That way, when you flip the switch to ON, the DRL is enabled.. Flip the switch OFF to disabled it. I'm not an electronics expert, but I'd be interested to see if this is possible.
Old 07-31-2012, 01:43 PM   #66
Mo707
Mo707's Avatar
This might be a dumb question, but why not just remove the bulb? At least then you wouldn't get that yellow reflection.
Mo707 is offline   Reply With Quote
Old 08-06-2012, 09:25 PM   #67
drftrdie
drftrdie's Avatar
Drives: Ae86,X2 , Scion FRS
Take your car to the dealer they can turn them off permenatly through the techstream at no cost to you took 2 minutes to do and they also changed my alarm sound and stuff and a/c around to better suit my elevation. IF they cannot turn them off they will have to order a new ecm for your car wich again will be no cost to you and toyota is more than happy to do it just tell them to turn them off there is a TSB out for them
drftrdie is offline   Reply With Quote
Old 08-07-2012, 03:03 PM   #68
Ishii Motors
Drives: Scion FRS
Because the DRL uses the High beam bulbs. If you remove the bulbs you'd have no high beams.
Ishii
The Following User Says Thank You to Ishii Motors For This Useful Post:
Mo707 (08-07-2012)
Old 08-08-2012, 11:27 PM   #69
about350
Guys if you dont like DRL just go to dealer as the man is saying.
The body ecu for the car has many customizable features which is a free service!!! Just roll through and request what you want. A recent TSB came out saying that toyota will replace your Body ecu so that the DRL function can be turned off at customer request and switched back on upon request. Any Toyota dealer can preform scion warranty work.
about350 is offline   Reply With Quote
Old 09-01-2012, 09:26 PM   #70
Hardrock4445
Hardrock4445's Avatar
Napa relay part # AR6034. Replace relay with this one. No drl, no trips to dealer. Not free but works.
Hardrock4445 is offline   Reply With Quote
The Following 3 Users Say Thank You to Hardrock4445 For This Useful Post:
Mil_Gates (02-17-2023), PANDA86 (07-14-2013), toeout (12-13-2013)
