Drives: 2020 BRZ Blue Pearl
Greddy Supreme SP causing CEL?
Hi everyone,
I was looking into getting a cat back exhaust soon and really like the Greddy Supreme SP catback. I want a rumble but not something crazy loud and not too much drone. The only mod I have so far is a UEL ftspeedfactory header. My concern/question: I found a YouTube video (link:
) and they have the same header as me as well as the catback system I want. Only difference is that they have a Motiv catted front pipe, which I plan to keep stock. They said they got a CEL about 7k miles after install and was able to remove it with an OFT. I don’t believe I would have a check engine light but I am hoping to not have to get an OFT at this time if I wanted this exhaust. Does anyone have any kind of insight in if I would have to expect a CEL if I got thuan exhaust? I was thinking as long as I kept cats on, I wouldn’t have to really worry about a CEL with what I am doing. Thanks in advance! |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
"The only mod I have so far is a UEL ftspeedfactory header." is it catted?
#3 |
Every Ounce Counts
Drives: 86
No - aftermarket exhausts alone do not cause the Check Engine Light (CEL) to turn on.
An aftermarket header without a Catalytic Converter may cause the CEL to come on.
#4 | |
Drives: 2012 Toyota 86
Toyota 86 in the building! |
#5 | |
I am planning on keeping cats on my exhaust as well. |
#6 |
Rust bucket enthusiast
By "no tune needed" they meant it won't explode, but it is unequivocally the cause of your check engine light
#7 | |
The check engine light that I brought up was because someone who posted a YouTube video had a CEL with the same header, catback that I want, but a Motiv catted front pipe. I plan to keep the stock front pipe. Last edited by AlexBRZ2; 08-22-2020 at 06:30 PM. Reason: Adding extra details. |
#8 | |
#9 |
#10 |
Drives: Bone stock
Seems you just got into the modding game. A catback cannot and will not cause CEL. The header without a tune for sure will. Not sure why you would get an aftermarket header and not tune the car. With the oft you can always flash back to stock on the fly. Just a tune and forget the warranty that you might not even use.
Sent from my SM-N960U using Tapatalk |
#11 | |
If the car has been running fine without a tune, would the tune only be necessary in order to increase the performance gains or would it potentially prevent something from happening that would have been a result of the header? Also, if I flash it back to stock, won’t the dealer see a change? |
#12 | |
friendly
Drives: 17' 86
I mean if they dealership really wanted to be ****heads and something happens to your engine they can likely tell that you swapped the header. Swapping the header can effect your AFR which can cause things to break. Is the likelihood high? No.
Seek comfort in discomfort.
#13 |
Drives: Bone stock
Why buy the header and not get the most out of it?
#14 |
My thought process was to get a bit of a gain now and then when the warranty is gone, tune it to get the remainder of the reliable potential out of it.
| WTB- Greddy Supreme SP | equachie | Canada Classifieds | 0 | 12-31-2019 06:40 AM |
| Greddy supreme sp vs. Perrin 2.5 | Aluma007 | Engine, Exhaust, Transmission | 0 | 01-03-2018 03:57 PM |
| Greddy Supreme SP | Senoko | Engine, Exhaust, Transmission | 20 | 07-14-2016 03:43 PM |
| GREDDY supreme sp | phongtphan21 | Engine, Exhaust, Transmission | 29 | 02-19-2016 03:22 PM |
| New from JRP: Greddy Supreme | Stav | Canada Classifieds | 14 | 10-01-2014 03:34 PM |
