Old 08-18-2020, 09:00 PM   #1
Palehispano
Palehispano's Avatar
Drives: Scion FR-S 2013
P0352 ignition coil “B” primary/secondary circuit
Wondering if any has had his code pop up and what did y’all do to fix it?
Palehispano is offline   Reply With Quote
Old 08-18-2020, 10:02 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
I see that this is your first post so welcome to the forums. Misfires are a common issue with our motors. If you do a search you will see there are many threads on it. The TL/DR is sooner or later you will need to replace the coil. In the short term if you swap around a coil from the opposite side of the motor you will probably find it wont trip a CEL for a period of time.
1974 TA22 Celica
2013 86 GT
Old 08-19-2020, 01:21 AM   #3
Palehispano
Thanks for the welcome and thanks for the advice will do!
The Following User Says Thank You to Palehispano For This Useful Post:
Turdinator (08-19-2020)
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
Coil Pack question (P0351/P0352 Codes) KN0W Engine, Exhaust, Transmission 2 10-10-2019 04:33 PM
P0352 - Coil Pack or Actual Curse? thE_iyE Issues | Warranty | Recalls / TSB 11 04-20-2019 08:33 AM
Has anyone resolved their ignition coil CEL issues? (P0351, P0352, etc.) edward Issues | Warranty | Recalls / TSB 41 11-06-2017 08:48 AM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open Rossi AFRICA 18 02-02-2016 06:26 PM
