Old 08-17-2020, 04:35 PM   #1
c0nd0r1t0
Drives: 2017 Toyota 86
Vland headlights on 17 86
Hi guys I recently just bought a 17 86 and need to get new headlights for it. I saw someone who had one with vlands that looked nice and wanted to opt for that look. Im still pretty new to lighting would I need a ballast, a certain bulb, or cables to work with the 86?
c0nd0r1t0 is offline   Reply With Quote
Old 08-17-2020, 04:38 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
If you plan on running HIDs, yes, you'd need a ballast and D2H bulbs.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
DriveDriftDogfight86 (08-17-2020)
Old 08-17-2020, 06:57 PM   #3
c0nd0r1t0
I'm trying to go the cheapest route since I'm on a budget would LED's work and without a ballast?
Old 08-17-2020, 07:01 PM   #4
Drifter X
Drifter X's Avatar
This is my setup. Cost effective and you get the better option. Aftermarket LEDs aren't nearly as good as aftermarket HIDs as far as light output. But it's up to you. I just really like HIDs.
Edit: yes, LEDs don't require a balast.
Old 08-17-2020, 09:39 PM   #5
Bowflex
Drives: Scion FR-S
I got these and they come with the HID kit installed. They are just rebranded Vlands. The instructions even say Vland.
https://www.ftspeed.com/part/lightin...z#.Xzsw6y2z3GI
Bowflex is offline   Reply With Quote
Old 08-17-2020, 11:52 PM   #6
c0nd0r1t0
I stumbled upon the old ones and they seem perfect can they use led h7 bulbs or does it have to be hid h7 just so I don’t waste my time buying the wrong ones.
Old 08-17-2020, 11:56 PM   #7
c0nd0r1t0
Also just to confirm ft speed is legit right just never used it before and have had bad luck in the past
Old 08-17-2020, 11:59 PM   #8
Drifter X
Drifter X's Avatar
I bought directly from the Manufacturer, Vland. The rep told me as far as HIDs go, it's D2H bulbs.
Old 08-18-2020, 12:32 AM   #9
Bowflex
Drives: Scion FR-S
They are legit and are probably one of the biggest retailers for our platform. The headlights are normally backordered so I wouldn't hesitate for long if you plan to order.
Old 08-18-2020, 04:53 AM   #10
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Wouldn't it be a downgrade to go from facelift LED headlights to Vland HIDs?
alex87f is offline   Reply With Quote
The Following 5 Users Say Thank You to alex87f For This Useful Post:
mrg666 (08-18-2020), PetrolioBenzina (08-18-2020), RToyo86 (08-18-2020), Tcoat (08-18-2020), Wally86 (08-18-2020)
Old 08-18-2020, 06:33 AM   #11
Yes
Old 08-18-2020, 09:28 AM   #12
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Depends on if you want to make changing bulbs a $30 issue or a $999 issue.
If the stock LED goes out (and there have been a few that have), it's a grand to replace it from with another OEM LED headlight assembly. $699 was the cheapest I could find it from an online source. That's per headlight.
If either of mine goes, I'll be going to a vland for price and future bulb replacement...
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 08-18-2020, 09:45 AM   #13
I did not realize that the LED headlights in later models require an entire headlight swap if the headlight burns out! Geez. That alone is enough reason for me to not buy the upgraded model.
Is this true for most OEM LED headlights?
Old 08-18-2020, 10:24 AM   #14
Maybe a justifiable one but still a downgrade.
Vland Headlights for 10 Series FRS JDMPR725 Electronics | Audio | NAV | Infotainment 3 04-04-2021 06:18 PM
VLAND Headlights hpanju Cosmetic Modification (Interior/Exterior/Lighting) 26 12-03-2020 12:30 PM
OLM HID headlights (looks like VLAND for BRZ’s) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 3 01-23-2020 07:55 PM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 09-16-2019 11:37 PM
FS BNIB Vland headlights statik Exterior Parts (Aero, Lighting, Etc.) 2 07-04-2019 01:56 PM
