Drives: '15 BRZ
Rattling Sound Coming from Front
Hey guys, does anyone know what could be causing this noise? It happens whenever I go over something bumpy, such as reflectors on the road, uneven surfaces in parking lots, crossing over train tracks. Anything that would jolt the car. At first I thought it was the hood catch, but I’ve adjusted that and it didn’t make a difference. In the video I’m driving over road reflectors. Thanks in advance.
#2 |
Rust bucket enthusiast
Could you tell us the modifications to the car
#3 |
Drives: 2013 WRB BRZ
First things to check:
- Sway bar endlinks - Strut top nut Pretty much stick a wrench on all the nuts/bolts under the wheelwell and make sure they are tight.
| The Following User Says Thank You to BigTuna For This Useful Post: | humfrz (08-14-2020) |
#4 |
Drives: '15 BRZ
#5 |
Drives: '15 BRZ
I checked the nuts on the diagonal strut bar and the 3 nuts that protrude through the body on the top of the struts and those were tight. Is there one particular nut at the top of the strut?
#6 |
Lug nuts all tight?
#7 |
Drives: '15 BRZ
#8 | |
#9 |
Drives: '15 BRZ
#10 |
Drives: '15 BRZ
Last night I took of the cap on both side and tightened the nut with my impact wrench. It didn't make a difference to the rattling noise. Any other suggestions? Normally I'm good at diagnosing issues, but this one is escaping me.
#11 |
Then my money is on the sway bar end links. The nuts could be loose or one of the ball joints themselves could be bad and knocking.
#12 |
Steering column. Mine had to be replaced around 60k. Somewhere here there's a thread and it was actually a clamp or bearing or something like that, it might even have been the thread I started a few years ago. I'm a few beers in now so work up your search fu and make it happen.
| The Following User Says Thank You to gravitylover For This Useful Post: | BigTuna (08-18-2020) |
| Rattling noise coming from car? | YgRoshi | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-22-2019 07:32 PM |
| Rattling sound coming from Brake booster and Master Cylinder | darkslide18 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-10-2019 03:22 AM |
| Rattling sound from front right side of car. | vramsaran | Issues | Warranty | Recalls / TSB | 14 | 05-07-2018 10:09 PM |
| Rattling noise coming from both doors, not speakers | kev60625 | Issues | Warranty | Recalls / TSB | 21 | 05-16-2016 09:52 PM |
| Weird rattling noise in cabin coming from front left | Webster10 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 03-01-2016 05:44 PM |
