#253 | |
The problem with manifolds is you can build one that works well in one part of the rev band but it sucks in other parts. So you end up with a compromise that works across the whole band. I used to own (well, still do) a 1995 Interga GS-R which had variable length intake runners that switched at 6200RPM (lots of people thought this was the VTEC switch point but it wasn't). So from 0 to 6200 it ran the long (dramatically longer) runners and 6200 - 8200 it ran short runners. It used vacuum to open 4 butterflies that sat in the middle of the manifold. Something like that would probably work well on our car and would probably solve the "dip". Problem is it adds weight and takes up more room. Something like this would probably cost as much as a turbo if it was an aftermarket thing. |
| The Following User Says Thank You to ermax For This Useful Post: | Ohio Enthusiast (08-12-2020) |
#254 |
Drives: Crapcan
I would be happy if someone came out with a manifold that only made more power from 4500-7200 and sucked everywhere else.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#255 | |
TRACKBREAD
No 2021 model
YES! Exactly! Other manufacturers use it. Its not black magic. Its like having different manifolds, each one for a different part of the rev range. |
#256 | |
This is essentially what Honda did on the Integra Type-R. They ditched the dual plenum intake and went with fixed short runners. My GSR pulled harder at low revs in but once we got into the upper band the Type-R would walk me hard. The Type-R was more purpose built so they didn't care about the lower band because you shouldn't be there anyways. They also wanted to shave weight. My boy racer days of never running under 4K were over 15 years ago. Today I'd prefer the dual plenum setup and more usable power at lower bands without compromising the upper band. But yeah, I totally get your desire for a manifold built solely for the upper band. |
| The Following 3 Users Say Thank You to ermax For This Useful Post: |
#257 |
Every Ounce Counts
Drives: 86
#258 |
Drives: 2013 BRZ Sport-Tech
That video was painful to watch. He needs to fix his driving position! Your arms should not be so outstretched on the wheel (and he can barely reach third). You should be able to rest your wrist on the top of the wheel.
I always have an issue with stock seats and a helmet but I'm 6'2" and need room for my legs and torso. He appears like his legs are extended out too rather than simply being in a comfortable position (supposed to be able to depress the clutch with you right foot). Either that's not his car or he never had an instructor look at his driving position. |
#259 | |
Drives: '15 BRZ RA
#260 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | nikitopo (08-15-2020) |
#261 |
More displacement and torque sound great. (as long as it still revs) if the renderings are accurate it’ll be a much less beautiful car. It looks pudgy. The fender and rear quarter shape of the current car are really killer. It’d be a shame if they messed them up.
| The Following User Says Thank You to Randoman5 For This Useful Post: | WildCard600 (08-15-2020) |
#262 | |
Drives: 1993 Caterham HPC Evo
https://www .shannons.com.au/club/fo...eel-technique/ ![]() When I was working/racing with the Bridgestone school I preferred to sit as low as possible and use the old school "arms out" style. Last edited by Stephen W.; 08-15-2020 at 01:07 PM. |
| The Following 5 Users Say Thank You to Stephen W. For This Useful Post: | Lightened (08-15-2020), new2subaru (08-15-2020), nikitopo (08-15-2020), Ohio Enthusiast (08-15-2020), soundman98 (08-16-2020) |
#263 |
Drives: '15 BRZ RA
Agree. The purpose of the video was to show that the 2stage intake manifold doesn't make much of a difference. At least not on this motor. There are plenty parts in the video to show this, independent of sitting position or other "errors".
Sent from my SM-A105FN using Tapatalk |
#264 |
Site Moderator
Drives: Supra
I posted this on the fan art thread, but for those that missed it.
Edit: I tried to remove some of the random watermark letters that he throughout the car. Don't judge, MS Paint was all I had to work with. ![]() ![]() ![]() For those that don't like the Supra nose.
#265 | |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
I agree that it is great news that Gen 2 will be lighter than the previous gen if that actually comes to pass.
So many modders have more cents than sense!
| The Following User Says Thank You to Rampage For This Useful Post: | Lightened (09-01-2020) |
#266 |
Every Ounce Counts
Drives: 86
| 2022 Nissan Z Coupe | WolfpackS2k | Other Vehicles & General Automotive Discussions | 1128 | 08-17-2021 07:34 PM |
| 2021 Suburban/Tahoe | Dadhawk | Other Vehicles & General Automotive Discussions | 16 | 12-13-2019 02:27 PM |
| 2021 BRZ Spy Shots | Dzmitry | BRZ First-Gen (2012+) General Topics | 4 | 11-25-2019 01:11 PM |
| All-new BRZ scheduled for 2021-2022 | Opie | BRZ First-Gen (2012+) General Topics | 49 | 11-05-2018 05:08 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) General Topics | 68 | 02-14-2012 08:16 AM |
