Old 08-14-2020, 12:18 PM   #1
antonio88x
Drives: '15 BRZ
Rattling Sound Coming from Front
Hey guys, does anyone know what could be causing this noise? It happens whenever I go over something bumpy, such as reflectors on the road, uneven surfaces in parking lots, crossing over train tracks. Anything that would jolt the car. At first I thought it was the hood catch, but I’ve adjusted that and it didn’t make a difference. In the video I’m driving over road reflectors. Thanks in advance.
antonio88x is offline   Reply With Quote
Old 08-14-2020, 12:41 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Could you tell us the modifications to the car
Old 08-14-2020, 01:36 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
First things to check:
- Sway bar endlinks
- Strut top nut
Pretty much stick a wrench on all the nuts/bolts under the wheelwell and make sure they are tight.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
humfrz (08-14-2020)
Old 08-14-2020, 02:35 PM   #4
antonio88x
Drives: '15 BRZ
Bone stock
Old 08-14-2020, 02:38 PM   #5
antonio88x
Drives: '15 BRZ
- Sway bar endlinks
- Strut top nut
I checked the nuts on the diagonal strut bar and the 3 nuts that protrude through the body on the top of the struts and those were tight. Is there one particular nut at the top of the strut?
Old 08-14-2020, 02:40 PM   #6
Lug nuts all tight?
Old 08-14-2020, 03:07 PM   #7
antonio88x
Drives: '15 BRZ
Lug nuts all tight?
Yeah, those are tight.
Old 08-14-2020, 03:10 PM   #8
BigTuna
BigTuna's Avatar
The one under this cap. You'll probably need a pass-through wrench or an impact though, or a way to keep the strut shaft from turning underneath.
Old 08-14-2020, 04:17 PM   #9
antonio88x
Drives: '15 BRZ
Okay, I have an impact wrench. I’ll check it and see if it’s loose.
Old 08-18-2020, 05:31 PM   #10
antonio88x
Drives: '15 BRZ
Last night I took of the cap on both side and tightened the nut with my impact wrench. It didn't make a difference to the rattling noise. Any other suggestions? Normally I'm good at diagnosing issues, but this one is escaping me.
Old 08-18-2020, 05:56 PM   #11
BigTuna
BigTuna's Avatar
Then my money is on the sway bar end links. The nuts could be loose or one of the ball joints themselves could be bad and knocking.
Old 08-18-2020, 07:44 PM   #12
gravitylover
Steering column. Mine had to be replaced around 60k. Somewhere here there's a thread and it was actually a clamp or bearing or something like that, it might even have been the thread I started a few years ago. I'm a few beers in now so work up your search fu and make it happen.
The Following User Says Thank You to gravitylover For This Useful Post:
BigTuna (08-18-2020)
Rattling noise coming from car? YgRoshi Scion FR-S / Toyota 86 GT86 General Forum 8 04-22-2019 07:32 PM
Rattling sound coming from Brake booster and Master Cylinder darkslide18 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-10-2019 03:22 AM
Rattling sound from front right side of car. vramsaran Issues | Warranty | Recalls / TSB 14 05-07-2018 10:09 PM
Rattling noise coming from both doors, not speakers kev60625 Issues | Warranty | Recalls / TSB 21 05-16-2016 09:52 PM
Weird rattling noise in cabin coming from front left Webster10 Scion FR-S / Toyota 86 GT86 General Forum 36 03-01-2016 05:44 PM
