Old 05-08-2012, 07:45 PM   #15
kanundrum
Drives: 2013 Whiteout FR-S
GT-Wing as a third of long-established campaign has begun
This is not a discount price, there is a campaign that presents a gurney flap that is attached to the machine of even the most current SUPER GT.
We have prepared an image. Some people think that 's what What gurney flap.
Like a lip that is attached to the rear side of the body wing guy is not.
Although I may seem useful but this is not enough to change course, even by setting a different size SUPER GT.
The effect is so well even in mini-wing circuit starts working from a much lower speed of course.
Is no doubt now that deals with a different and usually buy so that ¥ 18.900.
Please note that not all items are subject only model.
Target products have been published in the image of the guide on the campaign.
The Following User Says Thank You to kanundrum For This Useful Post:
ESBjiujitsu (05-09-2012)
Old 05-08-2012, 08:38 PM   #16
Brian S
Drives: Hinda Civic
One thing I will definitly be adding first are those gorgous crank and alternator pulley's. The color and machining involved are pure art.
Brian S is offline   Reply With Quote
Old 05-08-2012, 11:33 PM   #17
Dimman
Kuruma Otaku
Dimman's Avatar
Reading about a Gurney Flap in Engurish is painful.
Because titanium.
Old 05-29-2012, 02:59 AM   #18
kanundrum
Was held in Odaiba, Tokyo, 20 days and 19 we showed you last Sun "MEGA WEB FESTA"
Seems to have ended very popular. Drivers and celebrities and machine related to the car was on display.
From the rack, was Katsuta kun will be participating in a demonstration run in the opening 86 booth
Is that the demonstration run at 86, was said to practice until Wednesday Fukui also bother the other day.
Click here to practice landscape
Demonstration run at the venue of this high-speed rotation of the flame Hakonori as usual?
Whether it came with? Put the player next to Sayaka co-driver ·
Were also made at the venue of the talk show guest.
Monster Tajima players, led by
Sayaka players · kun and Katsuta
Although kun said Katsuta, and Larry has played well as advertising has recently been recognized a long time in the event these Until now I was a lot less rally race ·
Car here, but I also do not know the car. . . What I would!
This car is produced by Mr. Masanori Sekiya machine yuan noble son of Kun Katsuta is actually very indebted.
And, of the title of today is ·
It suddenly appeared that the player is the president Akio Toyoda Morizo ​​what Nana · · ·.
I think everyone was surprised appeared rainy day.
I was riding experience demonstration run next to the rack 86 and ·
So far, I see! What is it I feel.
Morisot player is also the driver what is still just ride next to ·
You need to make demonstration run was his own grip the handle 86 to the rack-de Nantes that
Thank showing off a driving technique in the judgment steering accustomed truly great.
It was good in the LF-A Nurburgring and 861 units have won the class, will also ride the rack 86 of the same color.
Have participated in the All Japan Rally under the name "GazooRacing rack 86" rack 86.
Thank you or is anyone · I who take it (. _.) Thanks
Old 06-15-2012, 01:49 AM   #19
kanundrum
The release date for the BSS kit · · · 86 & BRZ of BILSTEIN has been has decided to test drive the other day in late July. Also determines the price, ~ s too late in the first minute of order Now if tax ¥ 218.400 / helper springs with front and rear
We are also one order was today (. _.) Thank you Gozaimasu
Order from El sport still, there were so many things in the kit is the order from the way users and the core system running a little unsatisfactory.
The Company We can also overhaul and change any settings BILSTEIN commercially available.
From in-house quickly and is safe to do.
If sending cash please send the dates decided by the arrival day before you send in a reservation even if from afar, I can send it the next day or same day.
(If your transfer will be shipped after payment is confirmed)
Those who will be visible in the setting changed from the beginning a new one.
Who thought because it made the change and setting overhaul passed by night is entrusted your basic morning, and I can also do it yourself, please contact the first damper.
(There may not be able to determine and do not see the kind)
First of all anything I please consult
Old 06-23-2012, 03:38 PM   #20
kanundrum
Final Gear Set is set to 86 & BRZ has received very popular.
2 Set the type of our products are 4.555 and 4.300 can be selected to suit the driving situation for the 4.1 and 3.7 is genuine!
We also added reinforced type is processed in both types of WPC in the other day.
WPC than traditional strength has improved significantly in a special shot peening, and durability is up, which is a type of shot peening.
Even in our time - new mission to have a rally earlier in GC8
There are situations that do not have a war, but also had normal shot peening, I learned that there is still useless WPC was.
If you are surprised by dubious try in that time has just WPC can also still, I was troubled to think that the mission Ranked # What a great trouble then is no longer
Could also look at the tooth surface, the dimples of the level I do not know is touched also reduces friction, is three birds with one stone in conjunction with the fall of the curtain up oil intensity will also strongly
Final gear was damaged it and say well Altezza TOYOTA!
The higher the price a little bit, please try us, so take a break from the increasingly high.
Old 06-29-2012, 09:38 AM   #21
kanundrum
Metal catalyzer for the first step 86 is now available from SARD.
Muffler and to NA in the above graph also look at the data it has been fine up!
Undoubtedly be the next Desuga BRZ & 86, the oil temperature, water temperature and severe in both sports driving oil cooler is required (our data)
Those who run more than it is an item you want absolute radiator.
This time from the SARD racing radiator is now released, so I also did campaign, to say who might chance Run alongside this season!
This, first, I will complete the second specification both metal catalytic converter because it entered the exhaust manifold will be something other items in the future also!
Old 06-29-2012, 09:39 AM   #22
kanundrum
Yesterday was a user of the BRZ will visit us from Kanagawa bother. This way your transfer from the GRB
Who are also available before, we have purposely come fast Kattobashi agent for evolution.
Replace engine oil & filter, transmission oil, differential oil of, each agent is administered to all evolution
To talk about Def rigid color while working, I was allowed to mount immediately.
The first is addressed to the jack on the front of the differential, remove the bolt of the front mount.
So something like this, and because there is a counterbore inside the circle then you snap the rigid color immediately, please fitted to suit the orientation.
If you have completed is so, if you tighten the bolts to the specified torque wore restored.
Innovation, is complete if less than 10 minutes if there is a lift.
Strengthening mount handy!
Are also being developed mount of the rear side of the current color.
Please look forward to it all means.
Old 06-29-2012, 11:06 AM   #23
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Are luck the only company to bring out an aftermarket crank pulley thus far? Looks good anodized in gold.......
Also in regards to the final gear set is this to have a working sixth gear in replacement of what would be said to be an overdrive gear? Or has it something to do with diff ratio? Sorry bit of a noob question but need to ask to learn.. Please someone explain.....
FT-86GOD is offline   Reply With Quote
Old 06-29-2012, 11:13 AM   #24
kanundrum
I think Perrin has one
Old 06-29-2012, 11:59 AM   #25
harajukukei
Drives: MB c230k
harajukukei is offline   Reply With Quote
The Following User Says Thank You to harajukukei For This Useful Post:
kanundrum (06-29-2012)
Old 06-29-2012, 12:10 PM   #26
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
wish i could read japanese.....
Old 07-24-2012, 04:07 PM   #27
kanundrum
· · · ElSPORT change lightweight pulley set design for BRZ & 86
Change the design side of the crank pulley set our lightweight elSPORT, even more weight reduction made possible by it.
I have one report was well even before the vehicle fuel consumption by up also engine response, and the lightweight of the overhang.
It has become a luxury product with a hard anodized finish and 7075 Ultra duralumin material, we use the material for high durability even considering it.
Please try it.
How is the new design products - fresh from today the completion of freshly
Price ¥ 33.000/1Set
County 20-1 Nagakute Aichi Iwasaku pond biwa months Aichi Prefecture Address: Contact
Katsuta and Wakasugi TEL :0561-63-0101
FAX :0561-63-3535
Second Tuesday, Wednesday: Closed Sun
Old 07-24-2012, 04:07 PM   #28
kanundrum
Speed ​​limiter release device we showed you the other day now on sale from SARD. Can not be produced because many, like the situation is not quite in time, you have finally arrived in late.
The mounting can be mounted in the coupler on wiring because only without hurt sandwich on your computer, is about 15 minutes working time.
Price is ¥ 52.500, you will be free of labor in the early reservation.
When I sold out Please note that your time might take a little stock first minute
FR-S PARTS CATALOG SYSTEM IS UP AND RUNNING TPO Scion FR-S / Toyota 86 GT86 General Forum 96 06-03-2015 06:16 PM
LUCK Motorsport 86 ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 18 04-04-2012 03:38 PM
Toyota 86 LUCK equipment Harinjo Scion FR-S / Toyota 86 GT86 General Forum 31 02-28-2012 03:18 PM
New Project x2 S2KtoFT86 Other Vehicles & General Automotive Discussions 9 10-25-2009 12:17 PM
