Old 08-06-2020, 09:54 AM   #211
Enti.Moose
Drives: 2020 BRZ Sport-Tech RS
Originally Posted by pslater View Post
yeah... impossible to know if they are running spacers up front or not. the RPF1 is always a great option (i know "everyone has them," but i happen to like how they look), 17x8 ET45 fits, and they're very light.
(also, congrats on the BRZ RS, fellow canadian and RS owner! )
It's funny because I have always liked the look of the RPF1, but just not on the twins for some odd reason.
Thanks my fellow Canadian It's been barely 2 months of ownership but I cannot stop smiling everytime I drive. Also been very disciplined during the break-in period (800km left to go!).
Enti.Moose is offline   Reply With Quote
Old 08-06-2020, 09:58 AM   #212
pslater
Drives: 2017 Golf R
I wish APEX made 17x8 wheels.
- Andrew
i'll second that!
pslater is offline   Reply With Quote
Old 08-06-2020, 10:00 AM   #213
Enti.Moose
Originally Posted by dragoontwo View Post
Should not need any spacers. I've got 17x8 et 48 OZ Alleggerita with no spacers. I am still on 215/45 17 though. Even using maxed out lower camber bolts, the rim clearance to the strut tower is about 5-6mm.
Would you eventually run 225/45 17, 235/45 17 or any other preference?
Old 08-06-2020, 10:03 AM   #214
churchx
churchx's Avatar
Drives: 2014 GT86
From listed two sizings, on x8, i'd vote for 225/45 - more common sizing thus a bit cheaper and wider tire selection, closer to stock diameter, slight stretch will sharpen steering by reducing sidewall flex.
Old 08-06-2020, 02:02 PM   #215
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If it were a more common size, I think a 235/40 would be great. I may stick with 215 for now as I'm going to be N/A for a while but we'll see.
Old 08-06-2020, 02:13 PM   #216
dragoontwo
dragoontwo's Avatar
Originally Posted by N_Raged View Post
Thanks, I have OZ Ultraleggera's in the same size and offset with 225/45R17 tires and only have 9/16" of clearance to the strut. I haven't added any camber bolts yet so I was worried about clearance when I do put in camber bolts. It's a bit too close for comfort given the tire flexes in and out during cornering.
Just crawled under the car, and still no signs of tire rub. Will edit with some phone pictures. The tire has less clearance to the strut than the wheels, and I think it sits more proud of the rim than they did on the stock wheels. This is with -1.9 deg camber.
Old 08-06-2020, 03:40 PM   #217
Enti.Moose
- Andrew
Amen.
Old 08-06-2020, 03:47 PM   #218
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Did you do the top OEM crash bolt as well? I guess with only an aftermarket camber bolt in the bottom hole it would mainly push the bottom of the wheel out. But replacing the upper crash bolt with the smaller bolt from the bottom hole would pull the top of the wheel closer to the strut.
N_Raged is offline   Reply With Quote
Old 08-06-2020, 04:30 PM   #219
dragoontwo
dragoontwo's Avatar
Yes. The lower bolts went into the top holes.
Old 08-10-2020, 04:30 PM   #220
CL._.86
CL._.86's Avatar
Drives: 2019 Toyota 86 TRD (BONE STOCK)
Rays Gram Lights 57DR 17x9 +38 TRD 86
Hey Guys! Just got some rays 57dr for my 86 TRD in size 17x9 +38. They fit easily in back and fit in front with about a millimetre (if that) of clearence. I might get a 2/3 mil spacer just for safety but its fine for now. Im thinking about removing the stripe, not sure though. Also wondering if i should add the gram lights stickers to the wheels (red). Tell me what you guys think!
CL._.86 is offline   Reply With Quote
Old 08-11-2020, 11:18 PM   #221
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by mixxxx View Post
Photo for 57DR 17x9+38
No spacers needed.
Can you please figure out if spacers are needed or not?
Old 08-12-2020, 08:43 PM   #222
seanp.97
seanp.97's Avatar
Drives: 2018 BRZ tS
I am sure it was assumed, but 17x8 ET35 OZ Ultraleggera fit as well - tons of clearance.
hey are these actually 17x8 or 17x7.5? cuz tire rack’s got ultraleggeras 17x7.5 et35, and it got me confused cuz i haven’t seen anyone talk or post about 17x7.5 ultraleggeras. does anyone know if they might’ve made an error on their website, or if they really do exist, do they also clear the pp brembos?
seanp.97 is offline   Reply With Quote
Old 08-13-2020, 05:07 AM   #223
calcal
Drives: 2019 Toyota 86 TRD SE
I have the exact same model and planning the exact same wheel setup lol.
I am debating 17 vs 18, but leaning toward 17 at the moment.
someone posted earlier stating it clears the brembo in front but now you said it is quite close, so I am a bit worried as I do not want to run any spacer.
I would say NO gram light sticker, my plan is to get the 57DR red sticker instead. For the TRD stripe, i was debating as well, I still have it on at the moment.
Is your car lowered already in the photo?
calcal is offline   Reply With Quote
Old 08-13-2020, 07:52 AM   #224
dragoontwo
dragoontwo's Avatar
Did you check the OZ website to see fitment options for that wheel?
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
