#85 |
Drives: 2014 GT86
Hmm, but $2.3K at japanparts, +shipping/import costs .. imho by such price good clutch type LSD looks better choice.
#86 |
Drives: '15 BRZ RA
#87 |
That is not completely correct: Torsen doesn't have a lock rate, as it's stucture goes from 0 to 99.9% (if both wheels completely loose traction it will work as an open diff).
GRMN LSD is declared to be a little more "open" on the first phase, to help entering the curve. So I think it has different gears on Torsen leverage, basically related to wider rear wheels of the GRMN. |
#88 | |||
Drives: '24 GR86
#89 | |
Drives: '15 BRZ RA
You can find more information here: https://torsen.com/ask-torsen-torque...nal-questions/ I am not trying to build a GRMN 86 replica. I wanted to solve a specific problem I had, caused by bad road pavement conditions. I found that the best option would be to use the specific diff and it works perfectly. Someone might say that an OS Giken diff or other clutch plate would be better, but everyone can have its opinion here. What I can say for sure is that GRMN spent a lot of R&D to build the specific diff and yes it makes a difference. Another thing to know is that Torsen (JTEKT Corporation) is actually owned by Toyota, so they know what they are doing. |
#90 |
This is what I said, you were talking of lock rate not torque bias ratio, that's a completely different thing...
#91 |
Drives: '15 BRZ RA
It looks that you still don't understand, but you are not the first nor the last. GRMN 86 differential has nothing to do with the wider wheels or about being more "open" like you said.
#92 | |
Drives: '24 GR86
But as you mentioned, the GRMN unit works best for you and the specific problem you had. That’s fine. If it works, it works.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | daviddgaf21 (07-25-2020) |
#93 |
Drives: ADM Toyota 86 GT
#94 |
Drives: '15 BRZ RA
Nice!
#95 | |
Drives: gt86
But Some work need to be done to make it run correctly Otherwise aftermarket ecu can bypass some sensor to activate the throttle plate inside to switch the long runner or short runner |
#96 |
Drives: '15 BRZ RA
Short length runners are for high rpm power and long length runners for mid rpm torque. This is a high quality factory spec'd intake manifold for getting a wider torque curve from this engine .
#97 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Awww where did the post go for the cool manifold??
#98 | |
Drives: gt86
still figure it out a how to run it properly if i use motec ecu |
| Tags |
| frs, grmn, gt86, st-autosport, toyota |
| GRMN 86 unveiled | nikitopo | Scion FR-S / Toyota 86 GT86 General Forum | 103 | 07-22-2020 04:38 AM |
| What kind of wheels are these on the GRMN 86 Prototype? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-10-2018 09:23 AM |
| New article on the GRMN 86 (Tuned race ready spec) | Wise | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 02-16-2015 11:13 PM |
| GRMN SPORTS FR Concept PLATINUM | PREDATOR786 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 01-21-2013 11:47 PM |
| GRMN | 70NYD | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-23-2011 04:29 AM |
