Old 08-02-2020, 04:51 PM   #1
blue_sky
Difficulty changing headlight bulbs
Hi,
I've been struggling a bit changing the headlight bulb, specifically trying to unscrew the power connector to the bulb using my fingers alone. Think its ok if I buy a 6" wrench to try to loosen it? I probably won't electrocute myself, right lol?
Thanks!
blue_sky is offline   Reply With Quote
Old 08-02-2020, 11:28 PM   #2
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I've never done it on mine but it should be pretty straightforward. Usually you just turn it in one direction or the other and it pops out. And no you won't electrocute yourself...you can also always disconnect the battery.
SUSPECT_BRZ is offline   Reply With Quote
Old 08-03-2020, 12:55 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
The connector just rotates. To undo, rotate it counter-clockwise half a turn.
Then, see the paperclip looking tab on the top left? That's the wire retainer clip. You push that in, and the slide it over to release the bulb
DarkPira7e (08-04-2020)
Headlight Bulbs phongtphan21 Cosmetic Modification (Interior/Exterior/Lighting) 4 07-31-2015 02:00 PM
OLM LED headlight bulbs bodayguy Cosmetic Modification (Interior/Exterior/Lighting) 30 07-21-2014 02:54 AM
FS: OEM Headlight and DRL Bulbs boredom.is.me Exterior Parts (Aero, Lighting, Etc.) 0 04-30-2013 08:18 PM
Changing parking lights to white LED bulbs JohnAyySays Cosmetic Modification (Interior/Exterior/Lighting) 11 03-13-2013 04:38 AM
FR-S headlight bulbs? takethat Cosmetic Modification (Interior/Exterior/Lighting) 4 09-14-2012 04:11 PM
