Old 07-28-2020, 10:24 AM   #1
oleiksine
Drives: Marcedes
Someone help, new user, wheels rubbing!
I recently bought a brz with 18 inch enkei rs05rr fitted with 235/40/18 tyres. But I find that when I'm going down hills and turning my front wheels rub somewhere in the fender. I think its behind the wheel itself but i'm not sure. Has anyone else had this issue and if so, what can I do to fix it?
Edit: I do not know the offset of the rims, but it wouldn't be that negative. Also im fairly sure its the tyre rubbing not the rim.
Edit: The car is also on a stock suspension and is not lowered.
Thanks
United Airlines buddy pass
oleiksine is offline   Reply With Quote
Old 07-28-2020, 11:00 AM   #2
Vital
Drives: 2015 BRZ
Without knowing the the wheel width and offset no one can really help much. Most likely its probably rubbing on the spring perches...
Old 07-28-2020, 12:56 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Even some pics will help.
Take a wheel off and look on the inside face. Offset is stamped on most wheels.
Old 07-28-2020, 06:44 PM   #4
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
while you take off the wheel. mark the areas with blue tape where you suspect it is rubbing on the fender/strut or wheel well.
Take her out for a spin and listen for any rubbing and then check the blue tape areas
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
timurrrr (07-29-2020)
Someone help, new user, wheels rubbing! josh.condor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-16-2020 03:03 PM
Will 18*8 +45mm offset wheels fit with stock shocks without any rubbing all around? tommyc321 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-15-2018 09:22 PM
*Anyone tried 215/50 tires on oe wheels? Any rubbing? Lonewolf Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-16-2017 11:55 AM
Widest wheels without rubbing on stock springs with eibach springs ? H214M Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-09-2017 12:41 PM
Any rubbing issues with 17x9.5 +40 wheels and 255/40/17 tires? Eazy-V Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-02-2014 10:42 PM
