#15 |
Drives: 2013 FRS
Jeeze that's a lot of info to take in. I understand basics and know that it's not some crazy thing to dump money into. I've waited on this and been patient for a while for a reason. I want the car to last. I don't rag it out every chance I get, that's where you get problems. I absolutely love this car and it would hurt me internally to see it go bad because of me.
I don't know how going catless and using winter tires work in Nevada but if anyone here knows let me know. I'm also new to the state. |
#16 |
Drives: Scion FR-S 10 Series
What part of Nevada are you in? When I lived in Reno I used a set of performance snow tires. They kept the car fun to drive, but when there was snow and ice on the ground it was controllable. Now that I am in Vegas I just have a set of 200TW summer tires!
#17 | |
#18 |
Drives: 2013 BRZ Satin White Pearl
I’d drive it stock for at least 6 months, in that way you know the car and can at least feel the difference once you put the mods on. Use good quality parts and do your research as others have said.
I’d start off with coil overs or lowering springs and a set of light weight (forged if possible) 18 inch alloy wheels and some high performance tyres. I think it’s the best bang for your buck, the car will perform better and look better too, with the 18 inch wheels filling out the wheel wells and getting rid of the wheel gap. At this point you then have wider gripper tyres as a starting point for adding more power if you want. Good luck. |
| The Following User Says Thank You to Dirty Harry For This Useful Post: | why? (07-27-2020) |
#19 |
The Dictater
Drives: '13 Red Scion FRS
My first mod was a set of full plastic/fiberglass underpanels that the American cars didn't get. Reduces road noise and drag a bit, and makes you take a look at the bottom of the car front to back.
If you do your own maintenance, I tell everyone who will listen about the wonders of the fumoto oil drain valve. I would start with 3 things in mind. Budget, what you want to change, what direction you want to change it and by how much. Folks can probably give you more direct answers if you can post any of the above information. |
#20 |
Drives: Scion FR-S
If your mods are going to be more performance focused than aesthetic focused, I suggest you make driving skills a priority. It will be the most effective performance mod you make and it is also the most fun mod to install (HPDE/track days, autocross). When you attend these events you will also see what cars are really fast and the kind of mods those people are using. (Especially autocross since you are required to reveal your mods for classing purposes)
Instagram: @racecar_4life
#21 |
Q. Bumpy roads?
A. 16 or 17 rims with some sidewall.(brake size dependant) 18" and up will start to lose some of the added suspension compliance characteristics that more side wall will give you. Unless all your roads are smooth. Then go 17"..... Your not driving a racecar.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#22 | |
Mix of good and shit roads where I live too. |
#23 |
Drives: 2013 Whiteout FRS
tires
The most underrated and overlooked modifications is a quality set of tires. Cornering grip and braking improvements will shave more time off your lap times than any bolt on power or suspension mod will do.
#24 |
Drives: 2020 Toyota 86
First mod I did was the MTEC clutch spring. Big help at least on my 2020.
| The Following 2 Users Say Thank You to troyguitar For This Useful Post: | jcw99 (07-23-2020), Silviacrazed (07-13-2020) |
#26 |
Drives: 2013 FR-S MT Hot Lava
For this car,whether it be for performance or looks,you should always start with new wheels and tires. The Prius tires are garbage and while kicking the back out at will on a set of 210's can be fun at times,this car should've come with no narrower than 225s,imo. Ever since I went with a wider wheel and tire,the car feels more like a scalpel on the road.Much more precise than the stock wheels and tires.
No matter what you do to your car,the tires are the only points of contact the road(unless you are one of those stance boys scraping the oil pan on the ground),so you might as well make sure they are the best that suits what you are going for. |
#27 | |
pessimistic skeptic
Regarding power mods ... no comments. |
| The Following User Says Thank You to mrg666 For This Useful Post: | why? (07-27-2020) |
#28 |
Drives: car
@DabbinTooHard I've had the car for 130,000 miles and only have a few mods which improve driveability, quality of life, or durability.
- K&N panel air filter - more vroom - Fumoto oil drain valve - makes oil changes easier, and I change my oil a lot. - Whiteline / Perrin positive shift kit - fixes shift quality and makes the driveline nice and tight - Sticky tires in size 215 or 225 - adjust clutch pedal actuation point so it engages closer to the floor - revised clutch throw-out bearing # SU003-07349 or 30502AA150 - ARP wheel studs - better durability for when you're taking wheels on and off a bunch. I have a couple more whiteline parts for the rear end and also planning on putting on a 2018-2020 suspension, and have a feeling these will go on the list of "must haves" as well. Last edited by radroach; 07-24-2020 at 11:59 AM. |
| The Following User Says Thank You to radroach For This Useful Post: | why? (07-27-2020) |
| Tags |
| 13frs, beginner, first mod, new member |
| Warranty and Modifications | Bakes86 | AFRICA | 5 | 10-22-2018 08:17 AM |
| Next 2 modifications to do on my FR-S | Ragingft86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-11-2017 11:32 PM |
| Crawford Modifications | jonnyfrank | BRZ First-Gen (2012+) — General Topics | 6 | 09-21-2015 09:01 PM |
| Suggestions on Modifications | Tomngt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-05-2014 08:01 PM |
| Latest modifications :) | ikkomaji22 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 04-14-2014 10:24 PM |
