| Software Tuning Discuss all software tuning topics. |
Drives: Sideways
Delicious Tuning Flex Fuel issue : Ethanol content sudden drops
Hi everyone !
I have a Delicious FFK for 12’ models modded for my EUDM ‘17 (details on this below) I am encountering problems with the ethanol content value : it suddenly drops to zero for an unknown reason, and I can’t use a flex fuel tune since it would mess up the injection and might run the engine leaner than it should. An important detail is that those drops seems to be directly linked to road bumps. Lots of bumps, lots of drops, no bumps, no drops. Green is the ethanol content : ![]() Any clue on what’s happening ? Thank you !! Here is a bit of the background story for those of you that would be interested : Long story short, after some mixup with a group buy, i ended up with a 2012 model FFK for my EUDM 2017 GT86. On 17’, there is no ground in the O2 sensor plug, so it had to be added by making a T connection out of the black wire of the O2 sensor to link it to a ground spot. Delicious suggested that I could add the ground myself. Of course, they offered to make the mod in house, but since it would have cost a 2way trip from US to FR, it does not look like a reasonable solution for such a simple mod. I used the ground spot that’s just below the fuse box. I made a weld for the T. Here’s my T that I stripped out from its heat shrinking protection to check it : ![]()
#2 |
Drives: FT86
check if the gounds\earth good also check volts connection
check if the drops shown in ecutek logging correspond to drops in ethanol content logged in blutooth app Last edited by steve99; 07-11-2020 at 06:24 PM. |
#3 |
Drives: 2017 Toyota 86
I had these symptoms.
https://www.ft86club.com/forums/show...&postcount=243 My cause was the flex fuel kit's feed pressure sensor was reading low, which triggers a "safety" feature of the kit to zero out the E%. The cause of the low feed pressure was the in-tank fuel sender pump not being fully seated. If your kit has Bluetooth and the pressure sensor, try downloading the DT app and reading the feed pressure. |
| The Following User Says Thank You to Mr_Eyo For This Useful Post: | steve99 (07-11-2020) |
#4 | ||
Drives: Sideways
I checked my ground (between the black wire and my battery negative, it looks solid with a nice and steady 0 Ohm) Quote:
My FFK could be ordered with a fuel pressure sensor option but I did not take it. Would that mean there’s no ‘feed pressure sensor’ at all ? |
#5 | |
#6 |
Drives: Sideways
I’d have to open the Delicious box to check that... I also contacted Delicious, I hope they will provide some advice. I will wait a bit for them to answer before opening the box.
Thank you ! |
#7 | |
PhoneFlash by EcuTeK
You can also check out our facebook page for more immediate help, as we check this far more often. https://www.facebook.com/groups/tunedbydelicious/ Regards, William |
#8 | |
Drives: Sideways
I will try this and post afterwards here and on your FB page (My application has just been approved) Regards, Nicolas. |
#9 | |
Drives: Sideways
Car idling, I monitored the ethanol content while moving and hitting bits of my FF kit. I could see some drops (around 1 or 2 drops per 2 min window), but I could not find any relation between what I was moving/hitting and the drops.
I went on for a drive and it seems that it occurs more often with bumps, while being on a bit of gaz. If I’m idling on neutral while rolling, there is less drops. Hence I’m considering something with the ethanol content sensor and the fuel feed... Bubbles ? or a similar problem to Mr_Eyo’s ? In my case the car accelerates pretty well, consistently and smoothly. Quote:
Could you feel anything with the throttle/acceleration ? Anyone knows whether the Delicious Tuning E content sensor signal sent to the D-Box is analog or digital ? |
#10 | |
#11 |
Drives: Sideways
Thank you for the details !
In my case I still run the stock fuel pump (NA setup, E85). Does anyone know if the ethanol content sensor signal sent to the D-Box is analog or digital ? If the signal is analog I could try adding a bespoke filter to smoothen the value and see if it removes the drops. |
#12 |
Drives: Sideways
UPDATE :
At the grey wire going from the D-box to the O2 sensor plug : Multimeter reads 3,143 V very steady most of the time. Some drops could be noticed, very sudden ones (I’d say a tenth of a second long) : - Once in a while (every 30s to 1min), drops to around 3,050 V. Usually nothing shows on the E% monitoring, and sometimes there’s a drop (small -40%- or big -0%-) - And a bit less often (every 1 or 2 min), drops to around 2,950 V. Then, but not each time, there is an E% drop (half the time drops to around 40%, other half drops to 0%) |
#13 |
Drives: Sideways
UPDATE :
Could it be some kind of interference messing with the signal ? I inserted a 0,5MΩ resistor between the Dbox output and the O2 plug to measure receiver’s impedance, and noticed something strange : During the 10 min that I left it that way, I haven’t had a single drop ! (Sent signal was lowered to 2,2V giving a 44% ethanol content) What’s mind bugging is that during the whole time, no drops while the connections looked like this : ![]() (do not try to figure out color coding ^^) Next step is to add a capacitor to smoothen the signal... Any idea ?? |
#14 |
I think you physically manipulating the connector caused something intermittent to make contact. Tear it down, manipulate it a bunch, then re-instrument it like you have it and see if the drops come back. If so, it's likely an intermittent open on one of the conductors. Don't add a capacitor, it would not address root cause and would only add phase lag to the signal going to the ECU.
| Flex Fuel Gauge and Boost Control based on Ethanol Content | DeliciousTuning | Forced Induction | 6 | 10-11-2022 05:37 PM |
| Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth | Fiskafan | Software Tuning | 26 | 05-13-2020 01:04 PM |
| Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Engine, Exhaust, Bolt-Ons | 9 | 01-15-2017 09:40 PM |
| Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Audio/Visual, Electronics, Infotainment, NAV | 4 | 07-16-2016 06:43 PM |
| Flex Issue: E% content drops at high rpm | sw20kosh | Software Tuning | 13 | 10-03-2014 12:49 PM |
