#309 | |
Drives: 2017 Subaru BRZ PP
If you are talking about a drop spindle kit, the dampers designed for factory arms, at least in my case with the CSG FLA, were tall enough to get the control arms parallel. This is with the bodies fully extended but leaving enough threads in the lower mount for safety. With the shock bodies fully extended, and with control arms at or close to optimum geometry, the car sits very low. If you purchased a taller lower mount to raise the car up an inch for example, your parallel control arms would no longer be parallel. They would now be facing down on the outsides. This is effectively the same thing that happens to 4x4 vehicles when they are lifted without correcting geometry Last edited by Var; 07-09-2020 at 12:25 AM. |
#310 | |
In particular, this allows for rally cars to run very long, low rate springs, to have huge droop travel, without bottoming out when landing from jumps! This video better visualizes exactly what the HBS does. |
#311 |
Drives: 2014 GT86
Roll center kits .. isn't it more about front suspension, KCA435 that is, which is from updated ball-joints/tie-rod ends for more lowered cars?
For rear i recall mostly LCAs with relocated shock mount points to retain shock travel even with more lowering .. not so much about angle of LCA itself? (as otherwise one would need to move rather LCA inner pivoting point at subframe to keep angle, no?), and of course diff risers to also retain axle angles/reduce wear on CV joints? |
#312 | |
Drives: 2022 GR86
#313 | |
Drives: 2022 GR86
The video is great indeed. Looks like dropping a sand bag, just a little more viscous than that ![]() I presume with a regular bump stop on the same rig the weight would bounce back up, and that's what you call "bottoming out". What I call "bottoming out" is "the damper is compressed to the point it can't compress anymore, or to the point it resists further compression at a rate much higher than the spring rate". In other words, when suspension no longer "works": impacts from bumps are transmitted to the chassis, and the tire has reduced traction. Having that said, for a HBS to prevent the tire from interfering with stuff around it, the damper body length should still be adjusted correctly. When it comes to RC / drop spindle kits that lower the car compared to stock suspension, that means the damper body should be proportionally extended relative to settings used with stock suspension. |
| The Following User Says Thank You to timurrrr For This Useful Post: | CSG Mike (07-09-2020) |
#314 |
#315 | |
Drives: 2022 GR86
It appears that the CSG FLAs are not really part of the problem here after all. Curious what RC kits are recommended by CSG to to achieve better suspension geometry at the same ride heights as one gets by just installing CSG FLAs with recommended settings on stock arms. |
#316 | |
The "correct" way to do it is the SPL FLCA and the SPL Bump Steer kit, for around $1600 in parts alone. These are adjustable with shims to your desired angle. That control arm has much more adjustability than just roll center compensation though. There are always more risks involved in having parts that are adjustable beyond our means and understanding. But the parts themselves are legit af Last edited by Var; 07-09-2020 at 05:49 PM. |
#317 | ||
| The Following User Says Thank You to Var For This Useful Post: | CSG Mike (07-09-2020) |
#318 | |
Some kits are adjustable, others are not. Kits like the Whiteline and SPL are adjustable with shims, and in theory, is weaker than a drop knuckle which has much more strength in the area. Drop knuckles are not adjustable, but most of them are set to a reasonable height expected of a car that's lowered. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | churchx (07-10-2020) |
#319 | |
The wisefab drops the rear 45mm at the knuckle, which means via motion ratio, it's about a 32mm drop at the damper. Quite conveniently, the CSG FLA's recommended drop is 1.4" ~~35.56mm, so the Wisefab kit + CSG FLA + extended sleeve = virtually stock geometry instead of the compromised geometry of a 1.4in drop. Quite literally, it's almost perfect. |
#320 | |
This is a horrible solution unless you want your customer's cars to have bad suspension geometry |
#321 | |
Pretty cut and dry here; most folks do the net 1.4" without RC for budgetary reasons, and live with the compromise. Creative solutions like a drop knuckle or extended top perch is precisely how longer dampers like Penskes or Ohlins are run. You have a setup on your car that I wish my budget (and classing) allowed for on mine. |
#322 | |
If you had a BONE STOCK stock car with a 45mm drop knuckle kit, the car would still have factory geometry. If you tried to raise it any further from where it is, or lower it any further from where it is, you have compromised geometry. But at least in the case of lowering, you're not sweeping past the optimum angle on compression. Your control arm will always be operating under that angle save for weird cases of excessive droop, which is not an issue generally and would be on the unloaded side anyway. However, if you raise your car, as the suspension compresses, the control arms (on the knuckle side) will travel from below the pickup point on the subframe, to neutral, to above. This transition will cause unpredictable behavior because of nonlinear and not even unidirectional changes in roll resistance and camber curves Last edited by Var; 07-09-2020 at 06:55 PM. |
| WTB Tein Flex Z | HachiRo | Want-To-Buy Requests | 1 | 09-19-2016 02:13 PM |
| tein flex z | mclovin85 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-14-2016 07:27 PM |
| TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day | CounterSpace Garage | Groupbuys | 47 | 02-18-2016 01:33 AM |
| Help wanted: Tein Street Flex for $950 or Flex Z or $820? | chezzy79 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 09-01-2015 10:33 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
