#1919 |
Drives: UK GT86
As standard it's set to 0.7, so I guess this is too. It's set in the tune to do it.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | JBezugs (07-08-2020) |
#1920 |
Drives: 2015 Lightning Red BRZ Limited
First drives with E85, how does this look?
I've got a 2015 BRZ with Borla UEL catless headers and a Manzo Catback. This week I decided to go the E85 route & was very pleased with the hp gain, but I worry about the safety of the engine. I have used the off the shelf tune with OpenFlash for stage 2 E85 and have only put about 60 miles on the car since. I just need help reading these data logs because tbh I have no idea what I'm looking at. All I want to know is if everything looks as it should. Any help would be greatly appreciated!
https://docs.google.com/spreadsheets...it?usp=sharing |
#1921 |
Drives: 2016 oceanic frs
I'm wondering if my fuel trim is a bit high? I'm on E85, injen intakes, and borla EL. I'm tuned using the OFT E85 Stage2+
https://datazap.me/u/vincenttchan94/ft?log=0&data= |
#1922 | |
Drives: 86 GT
#1923 |
Drives: UK GT86
The theory is that it's safer, but if you have a tunes specifically for your setup then you shouldn't see much deviation from IAM of 1 and therefore it would be fine to use that as the default.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Compelica (07-14-2020) |
#1924 |
Drives: 2013 Subaru BRZ
Hello! I'm trying to diagnose a hesitation issue that happens sporadically between 2.5K and 3k RPM.
I managed to get a datalog of the event: https://datazap.me/u/entaroadum/hesi...&data=1&mark=8 Thanks! |
#1925 |
Drives: TRD R.S. 1.0 FRS
hello,
My tuner said that my wastegate pressure is 9 psi naturally. From what I'm looking at it shows about 8psi. I'm looking at Manifold Absolute Pressure. Am i looking at the wrong parameter? https://datazap.me/u/bboyairrick/boo...13-21-54-87-88 |
#1926 |
Drives: 2017 Toyota 86
Could someone check out my log and tell me how it looks. 2017 '86 auto, stock, OFT v4.03 stg.1. WOT pull in 2nd. Thanks.
https://datazap.me/u/daily86/oft-v4-...1&zoom=830-915 |
#1927 |
Drives: 86 GT
@Kodename47 and @steve99 hope to get a few minutes of your time. Got my first few logs done with WOTs back to back and some town driving. Any thoughts on it, or anything out of the ordinary?
WOT: https://datazap.me/u/compelica/wot-w...&data=17-20-32 Town driving: https://datazap.me/u/compelica/wayne...?log=0&data=17 First thing I notice is that I'm getting consistent timing pulls at around 5K rpm on WOT. Still learning at this, but instead of pulling timing from Base Timing B table, is there anything I could do to reduce knock at that area? Will try other fuel brands first but wanted to see if there's anything that I can understand on how to fix it. |
#1928 | |
Drives: FT86
knock you can add fuel , reduce timng and maybe run more direct injection. You already down in high 11 afr so maybe reduce timing amd try running more di injection. Or find better fuel |
| The Following User Says Thank You to steve99 For This Useful Post: | Compelica (07-28-2020) |
#1929 | |
Drives: 86 GT
I notice that the common answer to fix knock is to always reduce timing to solve it. Now I do get however that reducing timing is a sure fix but would that be less performant which is counterproductive on maximising performance for a given target fuel and mods. If stock roms are going rich to 10 AFR surely adding fuel to knocky areas would be a better solution? Or... is it because adding fuel complicates things versus just dropping timing? Appreciate it
#1930 | |
Drives: FT86
10 afr is way to rich for max power its to save cats in header max popwer is theroeticly 12.5 on petrol but poorer quality fuels or high compression engines its more like high 11 to low 12. Its a balancing act between ignition timong amd afr, richer ie below 12.5 looses power and more timong increases power untill you get to MBT which you almpst never do on petrol so your jist knock limited |
#1931 | |
Drives: 86 GT
#1932 |
BRZZZZZ
Drives: 2013 BRZ Whiteout
Hello, Can someone please have a look at my logs. Just got it back on the road after some trans work and been playing with MAF scaling. Car feels good, but not sure if AFT and LTFT is okay or I'm missing something.
2nd gear WOT log: https://datazap.me/u/sideways/log-15...a=1-6-7-8-9-10 Perrin intake, OFH, Perrin OP, Invida Q300 CB Thank you. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
