OEM Tail light connectors
Looking to wire the fog light as 4th brake light. Wanted to do a plug and play solution. I think I found the connector and a source. Not 100% positive these are the right ones but pretty sure they are. Ordered some and will update post later to confirm either way.
Sumitomo TS 090 A guy in Japan sells these. Bought some other connector from him for my Honda before. www.Easternbeaver.com |
#2 |
Drives: '14 BRZ
I'd be interested if they turn out to be the correct connectors.
Sent from my SGH-I337 using Tapatalk |
#3 |
Drives: 2013 FRS- Hot Lava
Interesting, having to cut into the OEM harness is the main reason I haven't installed rear fogs yet. Let us know your results.
#4 |
Correct Connectors
So i got the connectors today and they are the correct ones. Took 10 days from placing the order from Japan to east coast USA with standard cheap shipping. Not bad.
These are the two parts you need to make up a cable. 4 Position TS 090 Male Connector Item# 4P-TS090-M 4 Position TS 090 Female Connector Item# 4P-TS090-F I checked the wiring diagram for the pinout. Wire colors ( i tested these with a multimeter) Light Green - STOP Black - GND Yellow/Green - Turn Red - Tail Going to crimp/solder up a cable to run my 4th brake light tomorrow. Dont expect any surprises. |
#5 |
Sorry but could you link to the actual connector? I clicked around on the site but couldn't find the two PN's you have listed. Thanks
#6 |
Would love to know where you got them and pricing.
#7 |
http://www.easternbeaver.com/Main/El...onnectors.html
On this page. TS series 4 position connector. $4.19 ea for male/female with crimp pins. You will probably need some sort of universal crimp tool. I have one at work so I didn't need one. |
| The Following User Says Thank You to aschnell For This Useful Post: | NemeGuero (04-08-2014) |
#8 |
Finally got my connectors! took about a week and a half. Gonna get started on my Y harness tomorrow!
#9 | |
Señor Member
Drives: '17 BRZ PP
That said, either you posted the wrong link or the website got updated and ruined the link, but that link takes you to HM and MT type connectors. The correct link to TS series connectors is this: https://www.easternbeaver.com/Main/E...090/ts090.html |
#10 |
Moutain Runner
I have a friend that makes PnP harnesses for 4th brake lights. They're like $12 shipped.
#11 |
IMCF
Drives: 2016 Subaru BRZ Limited
#12 |
Moutain Runner
#13 |
Drives: 2013 subaru brz, 1979 toyota hilux,
| Valenti tail light signal light issue | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 70 | 12-03-2017 01:49 AM |
| Tail light ? | mousekilla15 | BRZ First-Gen (2012+) — General Topics | 2 | 07-30-2013 09:03 PM |
| **Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** | nigel-jdmparts | Exterior Parts - Lighting | 13 | 04-30-2013 01:14 PM |
| FS - Light tinted tail light overlays | seven | Exterior Parts (Aero, Lighting, Etc.) | 0 | 01-26-2013 11:05 PM |
| experiencing tail light + fog light condensation? | whyreeto | AUSTRALIA | 20 | 01-15-2013 12:15 AM |
