Old 07-04-2020, 01:41 AM   #1
fillthee
Drives: 2013 brz
Does the C light inside the 2017+ BRZ headlights stay on when installing on a 13 BRZ?
Hello,
I might change my headlights to a set of 2017+ and don’t know if the DRL light inside will stay if I install them on my 2013 BRZ. On 2017 BRZ’s the DRL is in the headlight so it stays on automatically, does that mean it’ll just be on if I install them on a 2013 BRZ that already has DRL’s?
I understand there are harnesses like the diode dynamics always on module that will have it lit up always, but I am just curious how it works with this swap.
Thank you
fillthee is offline   Reply With Quote
Issues installing Release Series Headlights staro0989 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-22-2018 07:12 PM
Need urgent help installing the Spec D headlights up and running. aznknightz17 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-16-2014 03:17 PM
BRZ LED strip problems(Inside the headlights) endless_pain Issues | Warranty | Recalls / TSB 4 06-05-2014 08:02 AM
LED DRL strip - DRLS stay on with headlights (but not using ACC/IGN wire?) kharn83 Cosmetic Modification (Interior/Exterior/Lighting) 4 04-24-2014 02:30 PM
Dash blinker stay on after installing leds Fr-Sheila Issues | Warranty | Recalls / TSB 14 02-05-2014 03:48 PM
