Old 07-23-2012, 11:25 PM   #1
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
FA20 vs EJ20 crankshaft
Crawford Performance posted this pic to IWSTI.com. I don't remember seeing it here, so hopefully it's not a repost.
The FA20 crank is the black one at the bottom. Interesting changes. It looks a lot beefier.
The Following 8 Users Say Thank You to Draco-REX For This Useful Post:
200hp/tonne (05-31-2013), Allch Chcar (08-09-2012), Bonburner (07-24-2012), Bristecom (07-24-2012), LeftFootBrake (08-10-2012), mike2100 (07-24-2012), os86 (07-24-2012), Sportsguy83 (07-24-2012)
Old 07-23-2012, 11:34 PM   #2
Tainen
Drives: First SWP BRZ-L
How does it look beefier? Sorry I've never really studied crankshafts before
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 07-23-2012, 11:39 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
The plates or whatever you call them look a little thicker. That could just be the picture though.
Old 07-23-2012, 11:41 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
The counterweights and webbing are thicker, the main bearings are larger in diameter, and it's tough to tell but the rod bearings look larger too. It's apparently 4lbs heavier than the older EJ crank.
Old 07-23-2012, 11:41 PM   #5
dabocx
dabocx's Avatar
Drives: Scion FRS
BRZ crankshaft weighs 4 pounds more apparently
dabocx is offline   Reply With Quote
Old 07-23-2012, 11:44 PM   #6
ahausheer
Re-member
Drives: Toyota camry
Toyota crank shafts are usually very robust no? Perhaps this was in part a result of Toyota? Larger bearing surface means less friction right per unit area right?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-23-2012, 11:57 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Yup. But this engine only makes 150lb-ft of torque and the open deck means it isn't made for large power levels. The EJ20 crank is probably good for 7K rpm, so I don't the extra strength is for just 400rpm.
So it's really interesting. I would have thought it'd be lighter to make the engine more efficient and accelerate quicker. But they saw a need for a heavier crank in a new, smaller, lighter, higher revving, and more efficient engine. So there has to be a reason.
Perhaps 7400rpm isn't the upper limit of the FA20 block....
Old 07-24-2012, 12:53 AM   #8
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
sure its open deck but there're lots of open deck FA blocks out there with +60k miles.
Wasn't the actual chambers short too, less movement in the actual block anyways.
I'm not too worried, considering Suby made it, I'm sure it can take a turbo without a hitch - this is an assumption because Toyota wanted people to be modding the heck out of this baby so I'm sure they made Suby make the block beefy.
Which what it appears to be .. and yeah I'm pretty sure it can rev higher .. according to one of the articles the the engine block was just tossed in and tested and they were surprised to see it hit 7k without a hitch and they went with it.
Old 07-24-2012, 01:19 AM   #9
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
It does appear to be MUCH stronger than an EJ crank, which even in NA for were fine for 10 - 11psi boost.
This new unit looks the goods for high compression + mild boost. Love it
Tradewind is offline   Reply With Quote
Old 07-24-2012, 01:29 AM   #10
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Is the black some kind of coating?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 07-24-2012, 02:55 PM   #11
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Larger diameter also means a higher bearing speed and more friction and requires more oil flow. The EJ cranks are quite robust. I only know a handful of failed OEM cranks.
The EJ205/7 revised oiling crank, not shown above, I actually have guys spinning well north of 9k.
The crank was beefed up because with the tighter bore spacing of the block architecture, the crank had to be shortened. With the increased stroke to make up for reduced bore (see bore spacing) the bearing overlap was reduced, hence the increased bearing diameter. The throws are then thickened to further strengthen the crank and reduce flexure that comes with the increased stroke (as stroke is a moment arm) and the flexure also increases with cylinder pressure (more so acceleration rate of the piston).
I can go on but I think you have the idea
EDIT: pending confirmation of actual values from the long block and not what another shop had told me...read with a 'spoon full of sugar'.
3MI Racing is offline   Reply With Quote
The Following 7 Users Say Thank You to 3MI Racing For This Useful Post:
bestwheelbase (10-17-2012), Bonburner (07-24-2012), illmatic (07-24-2012), industrial (09-13-2012), LeftFootBrake (08-10-2012), mike2100 (07-24-2012), MrAmalto (05-10-2014)
Old 07-24-2012, 03:28 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
So do you feel the FA20 crank is adequately built for its current application (86mm stroke, 151tq, 7.4Krpm), or do you feel it's overbuilt?
Old 07-24-2012, 04:18 PM   #13
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Please go on, I wanna read everything you can say about our engine blocks!
I'm hoping this block is 'overbuilt'
Old 07-24-2012, 04:36 PM   #14
SkullWorks
Drives: SSM LT MT BRZ
alright...I'll take the bait,
what is the boreXStroke of the old EJ20?
I had been lead to believe they shortened the stroke and increased the bore form the normal Subaru 2l formula... but increased bearing diameter and less bearing overlap doesn't add up to a shorter stroke, or a tighter bore spacing.
What did I miss?
FA20 Dimensions Matador Engine, Exhaust, Transmission 9 07-31-2013 12:45 AM
Which oil filter for the FA20? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 58 07-09-2012 12:21 PM
FA20 Interference... phm14 Engine, Exhaust, Transmission 3 07-02-2012 06:18 PM
ej20 swap possible? jordydiaz Engine Swaps 4 06-13-2012 11:16 AM
HKS s/c FA20?? Rome Scion FR-S / Toyota 86 GT86 General Forum 6 04-04-2012 12:13 PM
