Old 06-19-2020, 12:05 AM   #99
mike_b
Drives: 18 BRZ
Originally Posted by Seiryuu View Post
Maybe you got your answer already but for anyone else wondering, it clears the Brembos with about 1-2 mm clearance. However, according to official fitment guides from BBS Japan and Tirerack, these "do not fit" (probably due to such minimal clearance).
Thanks for following up!
mike_b is offline   Reply With Quote
Old 06-22-2020, 11:37 PM   #100
mike_b
Drives: 18 BRZ
Another example showing they fit. Looks great.
https://www.taiyakan.co.jp/shop/mito...owcase/491234/
Old 07-18-2020, 11:48 PM   #101
mike_b
Drives: 18 BRZ
I got mine and they do indeed fit and look great. Clearance is about 3.0-3.25mm at the closest point on PP Brembos.
The Following 3 Users Say Thank You to mike_b For This Useful Post:
JAS4 (10-06-2020), Seiryuu (07-21-2020), timurrrr (09-02-2020)
Old 07-19-2020, 03:27 AM   #102
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Nice rotors btw. Are those girodiscs?
N_Raged is offline   Reply With Quote
Old 07-19-2020, 09:33 AM   #103
mike_b
Drives: 18 BRZ
Yep. Girodisc 2pc front and rear. They are incredibly light compared to stock. Between the wheels, tires, and brake discs I lost about 11lb of rotating mass per corner.
The Following 2 Users Say Thank You to mike_b For This Useful Post:
N_Raged (07-19-2020), timurrrr (09-02-2020)
Old 07-19-2020, 11:00 AM   #104
N_Raged
Old 09-01-2020, 11:13 PM   #105
mike_b
Drives: 18 BRZ
Whew. I love it.
MrSkubi (09-09-2020), Racecomp Engineering (09-02-2020), timurrrr (09-02-2020)
Old 09-02-2020, 12:03 AM   #106
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Whew. I love it.
Nice setup! Love the Girodisc rotors! Do they make them in sizes for PP Brembos now or did they make you a custom set?
Mike_ZN6 is offline   Reply With Quote
Old 09-02-2020, 12:31 AM   #107
mike_b
Drives: 18 BRZ
Ken at KNS brakes hooked me up. The rear rotors are from an STi application but they are dual drilled and work on the BRZ pp brembos. You do have to trim the metal backing plate of the outside pad to the contour of the pad face and the pad with the squeal tab must go on the inside. The front rotors are 6.0lb lighter per corner and the rear rotors are 5.3lb lighter per corner.
JAS4 (10-04-2020), Mike_ZN6 (09-02-2020)
Old 09-02-2020, 04:36 AM   #108
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Can you share the part numbers for the rotors?
No customization was needed for the fronts?
Old 09-02-2020, 09:58 AM   #109
mike_b
Drives: 18 BRZ
Front giroA1-007
Rear giroA2-095
Fronts required no modifications
JAS4 (10-04-2020), Mike_ZN6 (09-02-2020), timurrrr (09-02-2020)
Old 09-02-2020, 11:56 AM   #110
Mike_ZN6
Mike_ZN6's Avatar
Awesome! Thanks for the info. This is on my list of planned mods.
I think this is the only matching front/rear 2-piece rotor setup available for the PP Brembos.
Old 10-13-2020, 11:40 PM   #111
86league
Drives: '13 BRZ Limited
Can you clarify the pad mods? You had to create clearance for the pad backing plate to the rotor? (the parking brake "drum"?)
What is the rough cost - fronts are $800/pair? Rears are ?
Thanks.
86league is offline   Reply With Quote
Old 10-14-2020, 07:00 PM   #112
mike_b
Drives: 18 BRZ
Thanks.
$800 per pair. $1600 total.
I had to grind the steel plate to be flush with the pad material. This only has to be done on the outside pad (the one without squeal tab). The pad with the squeal tab goes on the inside and does not need to be trimmed.
Here is a pic of the procedure.
The Following User Says Thank You to mike_b For This Useful Post:
Mike_ZN6 (10-14-2020)
Wheel Directory: OEM Subary BRZ (JDM STi Version) 17x7.5 +48 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 76 05-03-2020 10:31 PM
Wheel Directory: BBS RK 17x7.0 +48 Laika Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 05-21-2017 07:31 PM
17x7.0 vs 7.5 G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-14-2012 02:32 AM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 09:04 PM
