Old 07-23-2012, 03:39 PM   #463
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Looks sexy. Coming back for a full read.
TouchMyHonda is offline   Reply With Quote
Old 07-23-2012, 03:46 PM   #464
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Nice. Loud as fuck though.
1. Does is have boxer rumble?
2. I thought EL headers kill hp due to restricted flow.
quik1987 is offline   Reply With Quote
Old 07-23-2012, 03:58 PM   #465
OrbitalEllipses
Drives: Attitude
Originally Posted by quik1987 View Post
Nice.
  1. No. The rumble comes from the exhaust pulses passing through the exhaust when the runners are not equal length.
  2. I don't know the technical terms, but I guarantee flow (measured on a flowbench) is higher on any aftermarket manifold. EL headers make more power from optimum runner lengths that separate individual exhaust pulses and then dump them at a merge at the same time. That's the basic explanation and probably contains incorrect terminology...what you need to know is that EL > UEL when it comes to making power.
quik1987 (07-23-2012)
Old 07-23-2012, 04:58 PM   #466
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Unequal length will have lessened effect on a turbo system because the strength of the sonic and pressure pulses are reduced compared to the 'static' exhaust pressure in the system. NA and Turbo manifold design are similar in principle but quite different in effect there of...if that makes sense.
Those searching for EL vs UEL manifolds for this application are barking up the wrong tree IMO. Then again, I'm all about function and not form.
Think of these exhaust pulses as a spring/slinky. So each time your exhaust 'pulses' is like you sending a wave down a slinky. Now the slinky will 'reflect' the wave back. These waves are what we use to tune the performance of a manifold. If your slinky is thicker or longer, the wave moves at a different speed. This means that the reflected time back to the start point (valve seat) of the slinky is different. This will net cylinder imbalance as the tuned length of the ports aren't the same. This can reduce scavenging effects on one cylinder compared to another or have increased reversion, which will effect combustion, detonation limits and AFR's. To what extent naturally depends on given conditions and applications.
We then go to the collector where you want to pulses to evenly dump into it to keep it's flow velocity going out to the exhaust and to help reduce scavenging effects on all the cylinders. Think of this as when you were a kid and making a wave pool (like all kids do). The unequal length runner is your dumb friend with no rhythm that kills the wave by pulsing at the wrong time lol.
I hope that helps to understand why you don't want to compromise your cylinder balancing in the name of a sound.
3MI Racing is offline   Reply With Quote
The Following 4 Users Say Thank You to 3MI Racing For This Useful Post:
blu_ (07-31-2012), Entropy (07-31-2012), flippy (08-10-2012), phm14 (07-23-2012)
Old 07-24-2012, 02:28 AM   #467
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by uspspro View Post
I vote for:
1) Keeping a primary cat
2) A metal heatshield for a more "OEM " look (so upon a brief inspection it doesn't look "modified")
As far as flow designs - I would test the current design vs. the torque biasing.
Ah you californians and your keep it stock looking, must suck that every cop is out there trying to ticket moded cars though so i dont blame you.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 07-24-2012, 02:37 AM   #468
cgrey
Drives: 2013 Argento Silver FR-S
$2500 + tow
cgrey is offline   Reply With Quote
Old 07-24-2012, 02:43 AM   #469
Travis
Travis's Avatar
Drives: FR-S 6MT Whiteout
Originally Posted by cgrey View Post
$2500 + tow
What?
Travis is offline   Reply With Quote
Old 07-24-2012, 02:49 AM   #470
Blue86
Drives: Sonic Blue 86GT Manual
$2500 + tow
Woh! I thought cops over here could be a hassle but that is a million times worse.
Blue86 is offline   Reply With Quote
Old 07-24-2012, 10:13 AM   #471
cgrey
Originally Posted by Travis View Post
What?
That's the fine in California for driving a car with a removed cat.
I believe the maximum fine for any business that willingly modifies a customers road going vehicle by removing their catalytical converter is $100,000 if caught. Swapping for performance cats doesn't count.
Have seen signs to that effect.
Old 07-24-2012, 02:26 PM   #472
Norcalmav23
Drives: SWP Limited manual BRZ
any idea when the headers will be released?
Norcalmav23 is offline   Reply With Quote
Old 07-24-2012, 03:40 PM   #473
sw20kosh
Drives: 2013 Black FR-S
$2500 + tow
No a cop in CA is not going to get on the ground under your car to check the catalytic converter/s. The most he will do is pop the hood and hand you a ticket to go see the State Referee (if something looks aftermarket and has no exemption sticker) or you can pay a fine (for me it was $400) if you don't see the Referee.
When you go to the referee he will check your catalytic converter/s and all other emissions equip as well as check for illegal parts. He will smog the car and will either pass/fail you.
If you pass you go to court and prove that the car passed and after a small fee you are sent on your way.
If you fail the car is illegal on the streets but you are allowed a certain amount of time to fix it and return to the Referee for re-examination.
This was the process for me at least.
Old 07-24-2012, 03:42 PM   #474
Tainen
Drives: First SWP BRZ-L
If you fail the car is illegal on the streets but you are allowed a certain amount of time to fix it.
so the catted namless header would pass, then? It'd probably pass smog, who knows about visual though... you can see the cat right there from the top of the engine bay on the downpipe and on the header.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 07-24-2012, 05:22 PM   #475
Xenocide117
Xenocide117's Avatar
Drives: 2008 Honda Fit Vivid Blue Pearl
If it needs a CARB stamp and doesn't have one it won't pass visual.
Xenocide117 is offline   Reply With Quote
Old 07-24-2012, 06:00 PM   #476
Bigus
Drives: Standard
Hi from europe Jason ,great works of art you're fabricating !
when will the headers be on sale ?
can you do a RHD version of this complete exhaust and will it fit the Gt 86 ?
Bigus is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
