#127 | |
Drives: Scion FRS Firestorm
#128 |
Drives: 2016 Series.HyperBlue BRZ
#129 | |
I have a turbo, an oil cooler, and will have the FBM pan. So i will have quite a bit more oil required. Lol
#130 |
Drives: 2013 Scion FRS
I can confirm that this pan is causing issues with oil backing up into the turbo due to not draining correctly. I filled my car with oil until it read dead center between the 2 dots on the dipstick, and when I removed the turbo drain line from the pan (to diagnose my excessive exhaust smoking and oil in the downpipe) over a quart came gushing out. The return hole on the pan, when the car is filled to satisfy the dipstick, is BELOW the oil line. The dipstick reading is no longer accurate with this pan when using the return port. I ran a supercharger for 4 years with this pan with no issues but that's because Rotrex superchargers dont use engine oil so I never had this problem.
#131 |
Drives: 2013 FR-S, 2017 BRZ
Pardon if this is asked and answered somewhere, but I haven't had and luck finding it..
Will this pan fit with Tomei EL header? The header sits fairly close to the pan, and looks like it might hit where this pan is larger than OEM.. pic from their website: https://www.tomeiusa.com/_2003web-ca...ku_equal_l.jpg also, would some heat shielding between the header and pan be beneficial? the pan itself is designed to shed heat from the oil, but that doesn't help if it's being cooked by a header! |
#132 | |
Drives: Hot Lava FR-S
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
| FRS Die-cast model | encity5 | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 02-24-2019 12:15 PM |
| Expensive, but cool Die Cast GT-86 | Kimsey47 | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 11-26-2013 05:12 AM |
| FS: Die-cast EBBRO 1/43 frs 86 | blanco | Miscellaneous | 4 | 09-25-2013 10:42 PM |
| Durability of cast wheels | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-06-2012 05:10 PM |
| Any Disney Cast Members here? | MF_DEUCE | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 11-18-2011 01:48 AM |
