| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 | |
Drives: Brz with wudebody. Hopefully boost
No noise from the door I will check the fuse |
#30 |
Drives: Q5 + BRZ + M796
The car will manually lock, right? You can use the key to unlock and lock the door, and you can manually move the door lock from inside the car to lock the door, right?
Assuming everything is installed correctly (harnesses into their plugs), and they fuse isn't blown, and there is no shorts in the electrical system from the impact, then all I can think of next is this door sensor in yellow. I believe it is an impact sensor. I don't know if it was triggered, and if it was then I don't know if they automatically reset or if they have to be replaced. I also don't know if they trigger something in the circuit that unlocks the doors and/or then cuts the electrical door locks, as a safety feature.
#31 |
I also thought about it more. There could be a chassis code that is triggered that needs resetting. Again, this could be for safety, so an electrical door switch doesn't force the doors to stay locked.
Use Techstream to see if there is a code that needs resetting.
#32 | |
I have my airbag lights on would that effect it |
#33 |
I honestly don't know, but maybe.
You can buy a Toyota Techstream CD and cable from Ebay for cheap. That's what I did. You can check the code and clear anything. Like I said, it could be something else. You could call Toyota/Subaru to see if a cool mechanic would let you know if a tripped door sensor needs replacing or could disable the electronic door locks.
#34 | |
It would work for a Subaru as well? |
#35 |
Site Moderator
Drives: Stuff
Door locks are handled via the BCM. SRS module is another unit all together. The PW shouldn't work either if the BCM is fried.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following 2 Users Say Thank You to Dave-ROR For This Useful Post: | Irace86.2.0 (05-25-2020), JD001 (05-26-2020) |
#36 |
#37 |
#38 |
Site Moderator
Drives: Stuff
No.
Out of 13 or whatever of these salvage 86s now only one had door lock/etc issues and it was a fuse that was blown. My track FRS doesn't have impact sensors/airbags/etc. Doors lock/unlock fine. All the cars when still wrecked with blown bags and unreset ABS modules, doors lock/unlock fine. If you want to eliminate the SRS system as a cause simply unplug the SRS module. It's behind and under the HVAC controls. I had a badly reset module before in a car and whenever it was plugged in it made the CANBUS go crazy. Door locks worked but a whole bunch of crap (including the starter 49 out of 50 times) would not. Unplugged it and everything else was fine again. So if the SRS module is causing CANBUS confusion unplugging it will stop it. We traced that down with Techstream - well sort of. We detected that non of the modules would talk to either techstream and my good OBD tool and just unplugged crap until the problem went away...
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Irace86.2.0 (05-25-2020) |
#39 | |
Ok I’ll check the fuse |
#40 | |
Is it possible it is the actuator |
#41 |
Site Moderator
Drives: Stuff
I added more to my post on how to eliminate the SRS system completely as you were replying, but go do that if you want to just eliminate the SRS system.
But for the door locks themselves there is a fuse just for them so the fact that everything else works but that makes it the primary suspect to check first.
-Dave
#42 |
Does your trunk open with the electronic button or fob?
| Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 | T0rt0r0 | DIY (Do-It-Yourself) Guides | 82 | 05-14-2019 01:46 AM |
| Doors won't lock. | mynameis940 | Issues | Warranty | Recalls / TSB | 9 | 03-15-2018 03:05 PM |
| Trunk won't open and doors won't lock/unlock | Mazikowski | Electronics | Audio | NAV | Infotainment | 13 | 03-05-2018 11:50 AM |
| Auto Lock (Doors) | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 67 | 11-13-2017 11:47 AM |
| Doors won't automatically lock | adan | Issues | Warranty | Recalls / TSB | 18 | 03-01-2014 11:02 AM |
