#211 |
Drives: 2014 GT86
@CSG Mikes: but what degrades in calipers? Doesn't rehauling/cleaning/replacing seals and guide rubbers/regreasing restore them almost like anew? Trying to imagine, what can wear/degrade in metallic parts in calipers/pistons to be noticeable in braking, if there are no scratches or alike at time of overhaul? :/
#212 | |
Drives: Crapcan
#213 |
Drives: 2017 86 860 Special Edition
#214 |
Drives: Crapcan
I should clarify I was mostly talking about why you would replace the whole caliper as opposed to just swapping the seals. Could cause them to get sticky too.
#215 | ||
Generally, if you are burning off outer dust boots, you are MASSIVELY overheating calipers. Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | churchx (05-11-2020) |
#217 |
#218 |
Drives: Crapcan
Ahhhh. Thanks for the clarification.
#219 | |
Drives: 2018 BRZ
#220 |
Drives: 2014 GT86
There are people that need to use for various reasons stock brakes (eg. class requirements or street legality for dual-used car in some countries). Dust boots are there mostly to keep road salt out & maybe some extra dirt/sand/dust, no? And in winter there are way less load/temps on brakes. Seeing no relation of using or not track pads when, well, tracking, and street pads elsewhere, related to if calipers have or haven't dustboots. One just needs to understand, that proper braking on track (even if with stock pads, that may underperform in several areas on track) most probably will burn off those dustboots. Though it seems beneficial to replace burnt off dustboots in autumn, when summer tarmac tracking season ends. They don't cost exorbitant sums (eg. SU00304523 + SU00304098)
#221 | |
Then you have to accept that the calipers are going to get hot. Have you ever seen a brake change in pro level endurance racing? They often change out the entire assembly during stops. Guess what's going to happen to that caliper? Straight to rebuild. Here's an example. |
| The Following 7 Users Say Thank You to CSG Mike For This Useful Post: | 53Driver (05-20-2020), churchx (05-12-2020), DylanJZA (02-01-2023), Grady (05-13-2020), Ohio Enthusiast (05-12-2020), Racecomp Engineering (05-12-2020), x808drifter (05-12-2020) |
#222 | |
T64-416Ax3=13,140shp
Drives: 2002 AP1 and 2015 F-150 EB (DD)
#223 | |
Because compromise ®
Drives: Red Herring
Don't blink.
#224 |
| The Following User Says Thank You to RayRay88 For This Useful Post: | Captain Snooze (05-20-2020) |
| The Truth Will Set You Free~ | Kiske | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-06-2015 08:53 AM |
| Moment of truth. Humor is welcome! | gt8613 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 11-11-2014 03:08 PM |
| any truth to this? | fluffy-reindeer-slayer | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-11-2014 09:00 PM |
| An inconvenient Truth | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 06-17-2011 11:35 PM |
