Old 05-07-2020, 02:15 PM   #57
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
in case anyone is interested in buying, I've set up a vendor account to sell some in stock items.
$380 shipped in CONTUS.
https://www.ft86club.com/forums/show....php?p=3328165
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
solidONE (05-09-2020), why? (07-26-2020), WolfWings (05-09-2020)
Old 05-16-2020, 06:25 PM   #58
WolfWings
WolfWings's Avatar
Drives: 2018 Subaru BRZ Premium, Blue
Springs arrived, great turnaround, everything arrived in great shape!
Just... now comes the 2-3 week wait for the TRD 86 Rally parts to arrive from Japan due to the the hastles of international post ATM before I wed the two together and get things bolted on. >_>;
WolfWings is offline   Reply With Quote
The Following 2 Users Say Thank You to WolfWings For This Useful Post:
mav1178 (05-16-2020), why? (05-24-2020)
Old 05-16-2020, 06:53 PM   #59
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I ordered a set too. Great customer service, quick arrival time. no issues and everything in order.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Old 05-16-2020, 06:58 PM   #60
mav1178
mav1178's Avatar
If it's EMS the backlog is 4 months, at least that's the info that was posted. None of it has changed...
https://www.post.japanpost.jp/int/in...423_03_en.html
Might want to figure out a better way to send it. DHL/FedEx/UPS is more expensive but at least you are not waiting months.
Old 05-16-2020, 10:27 PM   #61
WolfWings
WolfWings's Avatar
DHL and comparable would've cost $400-600 for the few options the company had for shipping, around as much as the entire suspension did since the rally kit without the springs is only $530USD.
I opted for surface, which yeah might be 2 months, but usually in my experience is closer to 1 month or so. If the wait gets too unbearable I can still put the springs on the OEM parts and rotate things around when the rally kit shows up.
Old 05-17-2020, 01:11 AM   #62
mav1178
mav1178's Avatar
no worries.
if for some reason your order is cancelled let me know, I can get TRD Japan stuff as well via ocean, turnaround time is 45-60 days.
WolfWings (05-17-2020)
Old 05-17-2020, 03:13 AM   #63
WolfWings
WolfWings's Avatar
no worries.
Thanks much, I'll definitely reach out if needed, I'm hoping these springs pair as well with these struts as it looks like they will.
The Following User Says Thank You to WolfWings For This Useful Post:
Capt Spaulding (08-10-2020)
Old 05-22-2020, 04:19 PM   #64
mav1178
mav1178's Avatar
Is there any interest in the TRD rally shocks? MS260-18004
I got some pricing back, realistically we are looking at around $650 USD plus shipping for each set.
Price is higher than Japanese MSRP but this is a landed price, FOB Chino 91710. If you were to buy it on your own from Japan, freight will probably add on another $200 or more if it's even shippable...
Edit: probably able to combine with Chuhatsu to do around $1000 each set of spring/shock. Not sure if there is a market for this in the US but at least the products are readily available. TRD springs look to be around $1100 as a package
Old 05-23-2020, 02:05 AM   #65
churchx
churchx's Avatar
Drives: 2014 GT86
But what are springrates of chuhatsu vs original rally shock springs? Are they close enough for shocks valving to match rates of chuhatsu springs? Also is diameter of springs same so that rest, like spring perches, are compatible & springs interchangeable?
Old 05-23-2020, 01:26 PM   #66
mav1178
mav1178's Avatar
The only question is regarding the spring rates of the TRD Springs. The shocks are sold separately and there is no indication that it needs to be paired up with a specific type of spring. Even the instruction manual in Japanese does not specify this information. Additionally, this spring and shock combo does not require you to purchase specific purchase or upper mounts to install, so OE equipment is reused.
Old 05-23-2020, 01:53 PM   #67
churchx
churchx's Avatar
Drives: 2014 GT86
@mav1178: trd rally coilovers & springs from earlier threads about them:
OEM vs TRD Rally
Front Compression ~560 540
Rebound ~1690 1250
Rear Compression ~735 400
Rebound ~1620 1120
Spring rates (kg/mm) OEM GT86(EU) vs TRD Rally
Front 2,3 4,6
Rear 3,3 5,2
Old 05-25-2020, 06:00 PM   #68
WolfWings
WolfWings's Avatar
Well as you copy-pasted later the "TRD Rally" springs are MUCH stiffer than OEM or these ones.
To put things in more readable perspective:
Code:
FRS BRZ TRD Chuhatsu
131 153 257 129 Front Spring (lbs/in)
211 195 291 206 Rear Spring (lbs/in)
    560 540     Front Compression
   1690 1250    Front Rebound
    735 400     Rear Compression
   1620 1120    Rear Rebound
The stock TRD springs are RIDICULOUSLY higher rates to end up lifting the car despite being shorter springs overall, but the problem as noted by one of the folks that installed the TRD kit was the springs are too short for full suspension travel. These springs are longer which avoids that concern.
Honestly laying out all the numbers like this makes me more excited, this may well turn my BRZ into a true 'grand cruiser' with the spring rates closer to the FRS but avoiding the 'riding on the bump stops' problem the twins sometimes experience, and with softer absorbers this should be very comfy.
This is coming from bicycles I admit, but less compression and rebound generally means a softer ride on harsh roads, both at the expense of some grip in various situations as the wheels don't hug as tightly. Since I'm running a wheel/tire combination 10 pounds/20% lighter than stock (205/55R16) I don't need the suspension to work as hard to hug the road.
Clipdat (07-26-2020)
Old 07-24-2020, 07:35 PM   #69
WolfWings
WolfWings's Avatar
This is months late I realize, since yeah shipping was hellish getting the TRD absorber set from Japan over to the US. Ended up getting here via literal courier to Hong Kong, from there into China Post and from THERE finally to the US.
Just literally picked up my BRZ from the shop and put it through it's paces, the best way I can describe the combination of TRD Rally absorbers + Chihatsu springs is "buttery smooth" and makes the ride a bit quieter as well as a lot easier to get in/out of the car shockingly.
I'll take some measurements later once it's settled out fully, but it's a well over an inch of additional height all around with that combo freshly installed.
If anyone spots this and wants to take theirs to an even better daily-driver setup, especially if you got one used so it has worn-out suspension right now, this combination is really, Really, REALLY good IMHO.
The Following 6 Users Say Thank You to WolfWings For This Useful Post:
churchx (07-24-2020), Clipdat (07-26-2020), mav1178 (07-27-2020), norcalpb (07-25-2020), Racecomp Engineering (07-25-2020), why? (07-26-2020)
Old 07-25-2020, 05:27 PM   #70
WolfWings
WolfWings's Avatar
So I've driven this for another couple hundred miles now, had a chance to try a few places I know well.
Biggest change? The additional suspension travel and body roll feels like it lets the car properly 'squat and scoot' so it's noticeably harder to get traction control pissed off at me. I can WOT while turning up onto highway onramps and get all the way through 1st and 2nd without the tires being exceeded, and I'm not running anything remotely sticky.
Likewise while there's more 'body roll' it's way more controlled. If feels like there's time to actually 'catch' the roll and work with it, instead of getting tiny wiggles that suddenly upset things. Not sure if it's just the added split seconds of travel time, or the softer + progressive bumpstops from the Chihatsu springs doing it.
I haven't had a chance to experiment on gravel/dirt yet, that's tomorrow, the above is all asphalt. And again I'm running a straight-up 'foul weather' touring tire (Vredestein Quatrac 5, 205/55R16's), so before I could spin rubber in 2nd if I turned off TC and tried.
But I'll definitely say these springs and the added height make a huge difference on making the toyobaru more relaxed to drive. It's far less "over-caffeinated chihuahua of sports cars" now.
The Following 3 Users Say Thank You to WolfWings For This Useful Post:
Clipdat (07-26-2020), mav1178 (07-27-2020), why? (07-26-2020)
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 09:51 AM
Anyone in the DMV with a lift? Rifle Mid-Atlantic 5 06-06-2016 04:35 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 12:51 PM
