#729 | |
Drives: 2020 BRZ tS
The cluster's Gear Indicator is based on a calculation of the gear you're in and the speedometer reading, so it has a delay built-in. It is not a sensor in the Trans or somewhere that knows what gear you've selected. |
| The Following User Says Thank You to LancePower For This Useful Post: | jcw99 (04-24-2020) |
#730 | |
Drives: TRD R.S. 1.0 FRS
#731 |
Drives: 2020 BRZ tS
I'm guessing Reverse is instant due to the Back-Up Camera.
#732 |
#733 |
Drives: 2016 Scion FR-S
Can someone clarify for me, does this adjust the physical position of the pedal or does it adjust the point in the travel of the pedal that the clutch grabs?
#734 |
I just did the adjustment. I see that it adjusts the position of the pedal. Going for a test drive now.
#735 |
Steve Bodalenko
Drives: Toyota 86 GTS
#736 |
The clutch operating mechanism adjusts to wear automatically.
This adjustment changes the amount the clutch is disengaged by changing the throw of the pedal. The stroke of the master piston is proportional to this.
#737 |
Drives: 2016 Toyota 86
#738 |
I have been playing around with this adjustment for a few days now. Personally, I think having the clutch pedal just slightly higher than the brake pedal, rather than just slightly lower, feels the best.
#739 | |
#740 |
Drives: MY14 86 GTS Manual Velocity Orange
for those with RHD versions:
#741 |
Drives: 2016 Scion FRS
Hello! Just had my clutch replaced to a Spec stage 2 and re-adjusted the pedal. Can someone please let me know if the clutch cylinder is fully depressed/ compressed? Also is that adequate play for the cruise control sensor? My clutch pedal is maybe a tiny bit higher than my brake pedal right now. I also made sure the cruise control screw is not pressing into to the clutch on its own. Want to make sure I did this correctly and the clutch isn't engaged...
https://imgur.com/9TtheVx Thanks! |
#742 |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 04:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 11:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 03:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 02:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
