Old 05-12-2020, 10:16 PM   #15
brzskids
Drives: 2016 Subaru BRZ Premium 6 Spd WRBP
Originally Posted by churchx View Post
brzskids: yes, they come that way. You don't need "backing plate shim" with those. But you need those shims/clips where "ears" of pads move in caliper (if not reusing/reinstalling those, then pads will rattle around).
Also, if old pads were worn down a lot, you may need to press in pistons a bit, and check after changing pad (and pressing in piston) on each corner brake fluid level. Thicker pad -> deeper pushed pistons for pad to fit in -> fluid level will rise. After 2nd-3rd-4th pad there is possibility for fluid to overflow (if it had been topped to normal level with old, thinner pads), if you don't remove excess fluid with eg. syringe.
This clears everything up thank you so much. Just to confirm, I can just save the backplates from my old pads right? Would there be any noise reduction benefit if I were to reuse them?
brzskids is offline   Reply With Quote
Old 05-13-2020, 02:22 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Obviously you can save them, but not sure you'll be able to reuse on pads not meant for such. BTW, also suggesting to visit DIY forum subsection on brake change or watch some vids on youtube, if you are going to change yourself. For example, i'd also think of cleaning some grime/dust from caliper, so that pad moves more freely, and relube slider pin guides during pad change.
Old 05-13-2020, 09:17 PM   #17
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
I just did this last week and swapped my pads to the ferodo DS250 as well. I used this DIY to walk me thru it
https://www.ft86club.com/forums/showthread.php?t=45713
Detailed enough for a noob to understand . I used this years ago changing my brakes the first time and used it again last week to make sure I didn't screw anything up lol. Hope this helps!
Husker BRZ is offline   Reply With Quote
Old 05-14-2020, 02:33 PM   #18
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
brzskids, What are your impressions of cold initial bite going from OEM pads to DS2500?
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Ohio Enthusiast (05-14-2020)
Old 05-18-2020, 04:43 AM   #19
brzskids
I am currently still waiting on my typ200 brake fluid + stainless steel lines to arrive before I install the pads. I will keep you all updated.
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 06:27 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 04:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
