Old 05-11-2020, 03:10 AM   #1
Katsu
Drift Boy
Katsu's Avatar
Drives: 2016 Subaru BRZ
Brake Pad for Dual Caliper Hydro e Brake
Fellow Drifters, what brake pads are you using for your dual caliper hydro e brake setup?
I'm currently running OEM BRZ rear brake calipers on my dual calipers.
Thanks!
Katsu is offline   Reply With Quote
Old 05-11-2020, 06:24 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
My guess - whichever cheapest.
Rationale being - unlike main brakes & their pads, ebrake doesn't partially drag, just quickly completely locking up, even if you do it often like in eg. drifting. No drag, just "on"/"off" -> no extra heat > no extra requirements for "dusting"/"noise"/"modulation", so imho just about any pad should be usable.
I don't have dual caliper ebrake, but if i'd had, i probably would choose going by line of thoughts as above.
Old 05-11-2020, 06:45 AM   #3
Katsu
Drift Boy
Katsu's Avatar
Thanks Church,
Did some digging and found that some Formula D drifters use EBC Yellowstuff.
Ordered some and hopefully they bite better than what i already have.
Old 05-14-2020, 11:24 AM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
I have been using stocks pads, and they lock it up fine. Maybe you could use a longer handle for more leverage.
Old 05-14-2020, 08:50 PM   #5
Katsu
Drift Boy
Katsu's Avatar
I noticed with the EBC Yellowstuf it does lock up better now, but its not quite there. I have the Chase Bays Hydro e brake with reservoir.
How are you bleeding you hydro e brake? I don't think mine is building up enough pressure in the line.
Old 05-14-2020, 09:38 PM   #6
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Got interior pics?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 05-15-2020, 12:12 AM   #7
ML
ML's Avatar
you did put the calipers on reverse? For example, the hydro caliper on the drivers side should originally have been a passenger side caliper from the factory. Otherwise your bleed screw will be to low and won't bleed right, which could cause it to feel bad.
Old 05-15-2020, 08:12 PM   #8
Katsu
Drift Boy
Katsu's Avatar
Yeah I flipped them so the bleeder was on the top. It's my second time installing a dual caliper hydro, I previously had a E46 drift car.
Thanks for the help guys
Here's how its setup:
Chase Bay Hydro e brake --> Residual Pressure Valve 2 pound Wilwood (increase pressure) --> Shut Off Valve (to park) --> tee fitting --> to calipers
Lines are all 3an
Here's some interior pics Sosick
The Following User Says Thank You to Katsu For This Useful Post:
ML (05-15-2020)
Old 05-15-2020, 09:57 PM   #9
ML
ML's Avatar
Nice, I definitely didn't make that mistake (lol) when I first installed it. The shut off valve is a really good idea though! I use the PBM hand brake and it has a little screw you can twist in to hold the lever for a parking brake, but your setup is pretty slick.
Old 05-15-2020, 10:44 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
I'd probably just keep stock parking brake with drums in parallel to hydro ebrake, daily driving usage wise. I wouldn't have much trust in hydro ebrake keeping pressure on parked for days/weeks car on incline. One thing are short pulls during drifting, other functioning for parking.
Of course, reminding that i never had hydro ebrake setup so those are just my guesses/thoughts.
Old 05-15-2020, 10:51 PM   #11
ML
ML's Avatar
you can't run both as the dual caliper adapter replaces the drum brake mounting plate. Also I always park with the car in gear and if I'm really paranoid I use a chok.
Old 05-15-2020, 11:13 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
ML: hmm, indeed so. Rechecked bookmarked dual caliper adapter from bookmarks, "You do have to remove the parking brake shoes and backing plate.". My wrong.
Old 05-16-2020, 01:17 AM   #13
Katsu
Drift Boy
Katsu's Avatar
Thanks, I had the valve on my last setup to. It works so nicely, the pressure from the valve never leaks and holds the brakes tight.
Here's a link if you want to buy one https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'll probably end up just keep on bleeding it until the pressure is perfect lol
ML (05-16-2020)
Old 05-21-2020, 10:19 PM   #14
Katsu
Drift Boy
Katsu's Avatar
UPDATE!
Finally got my hydro working
Here's some steps for anyone that was lost like me
1. Make sure your Calipers are bleeder side up
2. Tighten all connections and verify no leaks
3. Bleed the brakes till your arm literally falls apart into pieces
Easy Peasy
Selling dual caliper hydro ebrake setup. $500 Allan13 Brakes, Suspension, Chassis 5 09-21-2016 09:28 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
F1 brake testing. Brake caliper porn! Captain Snooze Other Vehicles & General Automotive Discussions 11 10-16-2015 01:55 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
