View Poll Results: Gonna wrap the car. Which color?
Matte Black 12 37.50%
Matte Orange 20 62.50%
Voters: 32. You may not vote on this poll
Old 07-23-2012, 03:29 AM   #85
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Originally Posted by JIMs|a|MILLION View Post
Great thread so far. It's good to see someone taking the hands on approach and fixing all the rattles themselves.
did 5AD follow up and fix the adhesive problem with the kit?
Thanks! Still working on it but yeah, they are taking care of me. Five Axis cares about their customers! It's taking a while because I had to travel to get this car and they want to make sure it's fixed locally so I don't have to deal with the inconvenience of heading north to fix it. I am a fan for life of Five AD based on how they care about their customers and product.
digital_assassin is offline   Reply With Quote
Old 07-23-2012, 11:01 AM   #86
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by digital_assassin View Post
Been another busy weekend working on the 86. Headlights are back on the car less LED's. This really sucks because I almost had the locations perfected but my wife noticed the color shift. I would have waited to close but need the car so if I am going to do any type of LED I will need to reopen.
I spent a lot of time this weekend killing the rattles that my stereo creates. The rear deck panel and 3rd brake light will give anyone with a subwoofer a lot of grief.
I took the rear deck panel out and insulated with 1/2" High Density Foam cut to the size of the panel and then forced everything back together. Nice and tight now, no more rattle from there.
The 3rd brake light is a bit of another issue. Lots of pieces and parts that are not fit together very well from the factory. The clear lens rattles against the housing and the led strip rattles against the clear lens. I ended up plastic epoxying all the pieces together in crucial spots to fix this.
The passenger door rattle we are all experiencing is mostly from the switch. I disassembled it and placed Bat Tape around the contact points of the pieces and shoved some 1" High Density foam between the back panel and circuit board. There was a little white pop out cover that needed to be silenced in both doors as well as the yellow plug right next to it. Bat Tape and foam solved this too.
Overall the rattles are mostly gone. Need to go through the dash and sort that out as well as the C Pillar. When removing the rear deck the C Pillar seemed like a spot that may rattle and now that the rear deck is quiet I think I am getting something from the C Pillars, but not very bad.
Maybe a How-To is in order?
I for one do not want any rattle from a car I spent $40k on.
Post quotes in 3.....2.....1.......
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-23-2012, 12:06 PM   #87
BioRage
Drives: ~_~
Sorry bud.
I enjoyed your car before this.
I'm going to hate on this, but to each their own I suppose.
Let Audi's be Audi's.
Join us! @ EightSixClub
BioRage is offline   Reply With Quote
Old 07-23-2012, 12:21 PM   #88
digital_assassin
Originally Posted by BioRage View Post
Sorry bud.
They were removed. Couldn't get them to look right anyway so I 86ed em over the weekend.
Old 07-23-2012, 12:22 PM   #89
BioRage
Drives: ~_~
:happy0180:
Old 07-23-2012, 12:24 PM   #90
digital_assassin
I suck at how-to's. I'm generally moving too fast and forget to take pictures
Old 07-23-2012, 02:27 PM   #91
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Where did you pick up this "bullet proof seal" any general automotive store? like a partsource type store?
Yah, don't worry about opening them. I am doing oven at 225 degrees for 12 minutes on a cookie sheet. To close I scrape out all the old buty (PITA) and lay in new for a bulletproof seal. Bake black side only at 225 for 10 minutes and then clamp them.
I may open up for a fourth time and put in XB LED Halos since the strips don't color match. Not sure if I want to though since putting the bumper back on is such a tedious task. The Five Axis lip makes this process more difficult due to the fender liner and lip fit.
Old 07-23-2012, 03:42 PM   #92
digital_assassin
It can be found at Autozone, Carquest, etc. It's what is used to seal new windshields to the car. 3M calls it Window Ribbon and it is generically called Butyl Windshield Sealant
You'll need 1/4" or 3/8" bead size. If you go the 3/8" route you can stretch it, it just needs to lay in the trough.
I'll take a picture of the packaging when I get home for the stuff I found at Autozone.
Old 07-23-2012, 05:16 PM   #93
DrPeaches113
Drives: 2013 FR-S Asphalt
Hey digital_assassin... thanks for those measurements a while back... haven't been back to the forum in order to thank you since my FR-S arrived Saturday! Got the HID kit, running LEDs, and halos from TRS, and I'm going to play around with what looks best... your pictures/advice are definitely going to help! Only problem is HIDs are backordered right now so it might be a week or two until I can take a crack at it :/ Anyway... thanks again!
DrPeaches113 is offline   Reply With Quote
Old 07-23-2012, 05:26 PM   #94
digital_assassin
No problem. Be sure to verify the LEDs are color matched! If I was going to mount them again I would probably use silicone, after playing around with locations. Watch out for reflections inside the lens. The bottom is painted black so placement will be critical.
Old 07-23-2012, 05:51 PM   #95
Synack
Boosted
Synack's Avatar
Drives: Sideways
Wonder if I could steal the LED's from the newer Lexus's.
Old 07-24-2012, 01:39 AM   #96
digital_assassin
Anything can be done given you have money and time Usually when trying to retro parts out of another vehicle you will need to buy some extra parts to sacrifice while perfecting the retro. The Lexus LEDs are fairly large and drilling the housing would likely be required somewhere along the line.
Old 07-24-2012, 11:08 AM   #97
digital_assassin
Driving to work this AM and while getting onto the freeway I heard a the distinct bang of rock to metal. Got to work and looked for the damage and there it was. Shit, first rock chip right side hood at the fender bump. It's pretty minor and validates my thoughts that the factory clear bra wound do shit since the car is so low. The rock chip is about a foot above where the clear bra ended.
Old 07-24-2012, 11:14 AM   #98
Synack
Boosted
Synack's Avatar
Drives: Sideways
I got on around the bottom of the front bumper a few days ago. I'm hoping that the Five Axis installation will cover it
advan, drift office, kraftwerks, plasti dip, tomei
Saw this Five Axis Edition in Irvine by 85 degree bakery. sexy! 07stealth350z FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 59 09-05-2012 07:57 PM
Hell yeah! FR-S Five Axis Edition owner! digital_assassin Scion FR-S / Toyota 86 GT86 General Forum 76 09-03-2012 12:19 AM
Five Axis Edition Scion FR-S Package (Officially Revealed) Dark FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 364 08-06-2012 07:30 PM
White FR-S Five Axis :D Synack Off-Topic Lounge [WARNING: NO POLITICS] 3 07-12-2012 10:32 AM
Five Axis Edition Scion FR-S @ Toyotafest 2012 Flipside909 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 43 05-14-2012 03:46 AM
