Old 05-09-2020, 04:38 PM   #1
radroach
Drives: car
Reinforce battery tie down clamps?
I've had the factory tie down clamps pop out on several occasions, probably jumping over a bump.
Pic of the factory clamps:
Is there a better way to secure the battery?
Old 05-09-2020, 06:09 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I have never had this happen to me, and I've been on track (and off-track) at high speed several times.
Make sure they're installed correctly and the nuts are sufficiently tight. Perhaps your battery is not quite the right size for the clamp.
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
humfrz (05-19-2020)
Old 05-10-2020, 11:47 AM   #3
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i tossed a small piece of plywood under it to take up the slack.
Old 05-10-2020, 12:09 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Sounds like you don't have them secured in the right spaces. There are a few places it feels like it fits, but each j hook has its own location and orientation. I've drives my car up a hillclimb type road that is extremely bumpy several times and my battery does not budge (I've replaced that battery as well)
humfrz (05-19-2020)
Old 05-19-2020, 03:07 AM   #5
Oh, as mentioned above, I suspect you don't have the tie downs installed properly -
I outta you, but when you realize what you are doing wrong - you'll feel bad enough -
VoltsFRS2013 (07-03-2020)
Old 07-03-2020, 12:51 AM   #6
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Never had this issue (given I don't track the car, however, I have swapped my battery once.)
While installing those tie-downs, you have to make sure you are going equally on each side as you tighten down, otherwise, the tension from one will cause the other to pop out. Get them both in the hole and thread the nut down till both sides are equally hand tight, slowly tighten each side.
Also note, those tie-downs don't need to be extremely tight. If your hand cannot move the battery it is tight enough. The tighter those get, the more stress on the side of your battery. Batteries expand slightly overtime when they're hot. Not a good combination of things to have inside your engine bay.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
humfrz (07-03-2020)
Does anyone know where to get spring clamps? Ryan GT86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-08-2020 11:07 PM
Battery Clamps CUSTOM BRZ_Kamil Cosmetic Modification (Interior/Exterior/Lighting) 3 05-13-2015 02:42 AM
What size clamps come in the vortech kit? Frs32907 Forced Induction 2 01-27-2014 03:28 PM
Clamps and Check Valves for FI sw20kosh Forced Induction 1 12-17-2013 07:32 PM
Reservoir Clamps/Mounts swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-15-2013 10:23 PM
