Drives: Subaru BRZ ‘14
Help with reverse camera
Hey all, I recently installed a Sony XAV-AX5000 and I need help with my reverse camera, it makes the quality of the video really bad with flicking after the car is turned on. But when I’m in accessory mode, the camera’s video quality is clear. What can I do about this image?
#2 |
Drives: Subaru BRZ
Ole @humfrz can help.. calling Mr Humfrz, calling Mr Humfrz, we have a query here that fits with your speciality..
| The Following User Says Thank You to JD001 For This Useful Post: | humfrz (05-09-2020) |
#3 |
Drives: Q5 + BRZ + M796
What rear view camera are you using? The stock one is 6v. Maybe the aftermarket head unit utilizes a 12v. Maybe you need a converter if so.
My Kenwood HU utilizes a 12v camera, and that is what I bought. I feel like people who bought the same unit with the stock camera just found a black screen--not a flickering screen--so I don't know if your problem is a voltage issue.
#4 |
ProCrastinationConsultant
how are you connecting the existing camera? is it a RCA connection?
#5 | |
Well, I'm sorry to say, that is just the early stages of the disorder. Soon things will move around. In the latter stages, things will zoom up on you quickly. The final stage, before they take your license away, big things will jump up behind you, with no warning. There is no cure, but you can minimize the damage by limiting parking where you have to back up.
| The Following User Says Thank You to humfrz For This Useful Post: | JD001 (05-09-2020) |
#6 | |
Drives: Subaru BRZ
#7 | |
#8 |
Drives: Subaru BRZ
I suggest that the next time you go rubbing just keep a copy of your Playboy stash by your side.
#9 |
#10 |
Looks like you are looking through a screen door.
Ok, does the vertical lines change or move right and left with RPM if yes then a line filter, or ferrite ring core that snappes on the video line might help. Sometimes looping it through twice works better. |
#11 | |
I’m using an aftermarket one from amazon, it’s camerasource. How can I check if it’s a voltage issue? Whet can get a converter? Sent from my iPhone using Tapatalk |
#12 |
#13 | |
While the engine is on it flickers bad, to where it goes to “no video signal” then back to the video screen Sent from my iPhone using Tapatalk |
#14 |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
I suspect there's a bad or highly questionable ground somewhere. I would think first to the camera itself, but the headunit's ground interference (if the problem is up there) could filter to the camera if the camera is powered off the HU. I'd check and re-do both and see if it improves.
| Need help with installing Camera Source's reverse camera for 2013 FRS | Ann13 | DIY (Do-It-Yourself) Guides | 9 | 09-30-2019 07:39 PM |
| Reverse Camera | Emissary_of_Pain | Electronics | Audio | NAV | Infotainment | 5 | 10-27-2017 10:13 AM |
| FYI - it's possible to add a reverse camera for $20. | SloS13 | Electronics | Audio | NAV | Infotainment | 25 | 09-09-2013 10:03 PM |
| Reverse Camera | FT86_Zero | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-05-2012 08:05 PM |
| Reverse camera? | dorkymork | BRZ First-Gen (2012+) — General Topics | 28 | 05-21-2012 10:21 AM |
