Old 05-04-2020, 12:02 PM   #15
M0nk3y
Originally Posted by ZDan View Post
Are you saying grip decreases with wear? Will keep eye on relative performance per event...
Correct, they're quick at the start of their life and as they wear then tend to give up grip due to how the tire was designed.
Car and Driver test shows the PS4S quicker in the dry and Conti quicker in the wet.
https://www.caranddriver.com/feature...-test-feature/
I'm kinda guessing that same vs. same the PS4S should be at least half a sec quicker in the dry, but maybe not, CSGMike suggests otherwise...
To make things more complicated, this was TR's test:
https://www.tirerack.com/tires/tests...y.jsp?ttid=223
No question, ECS in completely standing water will be quicker simply because of void tread vs PS4S. PS4S is quicker (IMO) in basically all rain instances because the chances of a monsoon event are slim to none (where you have visible standing water). I've found for the most point all rain instances are either wet (not standing) or in a transition phase where it's wet going to dry. In these cases, PS4S will be significantly quicker than ECS (which is something none of these tire tests show because it's always just full bore wet). The transition phase from ECS to say RE-71R is basically once dry patches start forming you need to switch ASAP or you're already late. PS4S you can let it almost become fully dry before switching because the tire still performs well under semi-wet conditions (as long as it's kept cool and doesn't overheat). If that makes any sense.
I decided to run Bilstien B8s in place of stock dampers so I'm taking a point there which bumped my min weight up a bit. So I'd have to run ballast even with 225 PS4S. I think 245 Contis at 2907 lb. should be about equal to 225 PS4S at 2965 lb.
Also was super-disappointed with Michelin PSS I ran for a couple of seasons on the street on my FD.
You can't compare PSS to PS4S. I can't even relate the two.
I was thinking the same thing, but other reasons tipped it to the Contis.
Have you run both PS4S and Conti ECS?
Tad bit late now but curious if you have comparitive lap times...
See how it goes at the track! If Sash kills me running more weight with less power on Rival S tires, I might consider those plus significant ballast...
I ran Conti ECS 245/40 on 17x9 and now same tire on same wheel in PS4s. Both for 2 years of DD/autox rain use. While I don't have track times on the actual track to compare, my thoughts/opinions are related to autox and how the tire performs under those conditions. So, threshold of grip and how the tire recovers is "probably" a bit more important to autox?
PS4S in the wet is simply like cheat mode. I can only compare against others in the class in same conditions when they were running RE-71Rs or similar and it is seconds.
I know the weight penalty is higher with A052s...but worth consideration
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
strat61caster (05-04-2020), ZDan (05-04-2020)
Old 05-04-2020, 07:41 PM   #16
CSG Mike
CSG Mike's Avatar
Remember that the Conti and MPS4S both will heat cycle, but the Conti physically can get hotter and thus, cycle itself faster and also showing higher friction (grip).
The MPS4S has a softer sidewall, which tends to help driver confidence with intermediate level drivers, but the sustained grip of the Conti is greater, given a comparison of fresh tires of both compounds.
The MPS4S lasts significantly longer than the Conti, and rides quieter/softer.
I used to compete in a class that mandated 220+TW tires, and have tried basically all the tires personally on my BRZ.
Nankang NS2R
Achilles 123S
Michelin PS4S
Continental ECS
Federal 595
Some others that I don't remember as the results were poor.
Teseo (10-06-2024), ZDan (05-04-2020)
Old 05-04-2020, 08:33 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Generally put 7 heat cycles on tires per event, 6x 15-20 minute sessions and then 5-lap TT (1 in, 3 hot, 1 out). Sometimes open-track too which'd be an 8th cycle. How many events do ya reckon they would they be good for?
Ah, how fresh is fresh?!
Very cool thanks for info
Old 05-04-2020, 08:47 PM   #18
CSG Mike
CSG Mike's Avatar
These tires will all be 1 lap wonders; take a slow outlap when new, and go harder when they're cycled as they wont heat up as quickly. Cooldown laps will work as long as the pavement isn't too hot. You can also pull into the pits and water the tires a lot between laps. If you have time, I would recommend outlap, hot lap, hot pit + water, outlap, hotlap, inlap.
As far as cycling goes, I'd say you'll get 4 competitive sessions out of them. Beyond that, it'll depend purely on how quick your competition is. First few sessions is fastest as usual.
For the fresh comparisons, it would be sticker vs sticker. I've used a few sets of ECS, but TONS of MPS4S, as that's my default go-to true street tire. It's value for strictly street use is unbeatable, and I've worked for some companies that were Michelin partnered, and effectively had an unlimited supply of 4S/CUP2.
Both of these tires run wide for a "normal" tire.
Old 05-04-2020, 11:11 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Welp, their good laps are going to be consumed in practice. Events are two days and time trial is the end of day 2, so 1st TT with them they'll already have six 15-20 minute sessions on them. TT is three laps with other cars staggered 20 seconds apart, so no coming in for tire spraying.
See how it goes... It's not gonna be practical to save tires for the TT.
Nice!
Depending how first event goes, I might get another set of tires for event 2. Which could be another set of ECS to save for TT, or MP4S, or Rival S.
Old 05-05-2020, 12:56 AM   #20
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Nankang NS2R
Achilles 123S
Michelin PS4S
Continental ECS
Federal 595
Have you tried the Yokos Neova AD08R? I got a brand new set SUPER cheap because of a store closure sale, and was wondering if they are going to be good for HPDE. Not looking to set records.
nico_rsx is offline   Reply With Quote
Old 05-05-2020, 02:42 AM   #21
CSG Mike
CSG Mike's Avatar
it isn't 220+ Doesn't qualify for this particular discussion.
That said, yes, I have.
nico_rsx (05-11-2020)
Old 03-30-2022, 08:44 PM   #22
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
For 5c (40f) - 10c (50f) and light rain wet track, do you prefer PS4S over ECS? I heard ECS is better in warmer temperature and PS4S still pretty grippy between 40f to 50f, is that true?
Rain a lot in my area especially March to May and September to November. Just want to think of back-up plan on which "wet" tire to go for.
Thanks!
botbs is offline   Reply With Quote
Conti ExtremeContact Sport vs Hankook R-S4 Guru Woodman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 06-05-2019 08:24 AM
Finally upgraded from stock tires to 225 MPS4S! Kushkaki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 06-04-2018 06:24 PM
FS: 2 Continental ExtremeContact DW- Sold bggns Canada Classifieds 2 05-03-2018 09:02 AM
Continental ExtremeContact DW vs Michelin Pilot Super Sport tread width 235/45/17 tracerit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-22-2016 10:32 PM
Sold - Set of practically new Conti ExtremeContact DW 255/40R17 Slick Canada Classifieds 1 06-25-2015 10:34 PM
