Old 04-26-2020, 08:44 PM   #1
kashup
Kash
Post Help - HKS el Header won't line up properly
So I bought HKS el headers (used) from a guy local to me.
When I'm trying to put them on it's not lining up properly. Is it normal? do I need to use lot of force to get them on? Please see the Pic below.
https://ibb.co/HXNbtBN
Am I missing something? The headers use to be on a 2016 GT86
kashup is offline   Reply With Quote
Old 04-26-2020, 08:45 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If it heat cycled it may have warped them. I had one before and had no issues with fitment.
MS, CSCS, TSAC-F, CPT
Old 04-26-2020, 08:53 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Normal. Thin metal tubes heated and cooled repeatedly. Use some muscle and push them apart.
Old 04-27-2020, 12:32 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
Do you have the header 100% unbolted, you didn’t bolt up to overpipe and or front pipe already?
Could try a heat gun just wear gloves, get it hot and muscle it on. It looks like it should be able to go on, maybe try having someone help you and push one side on but just hold it at the tip of the stud and get the other side on it doesn’t look much off, if one side is fully pushed on the other side might be angled causing the interference.
Old 04-27-2020, 03:27 AM   #5
bobel
Drives: GT86
This is not unusual, I recently built my engine, while doing it I left my headers off the car on the workshop floor for about 3 months. When I went to put them back on the car I had the same issue as you.
I tried placing a bottle jack between the flanges and spreading them apart, unfortunately they just kept springing back, in the end I bought a new header.
Funnily enough the new header shipped with a spreader bar installed between the flanges, just a metal rod with two bolts at either end but obviously even the fabricator is aware it can happen over time.
You may be luck and a little force or heat might relax the tubing enough to get it in there.
Best of luck either ways
bobel is offline   Reply With Quote
Old 05-01-2020, 09:49 PM   #6
EvolutionRevolution
Drives: SCION FRS 2016
Strange.. I recently put a used HKS EL on and fitment was spot-on. Good luck.
EvolutionRevolution is offline   Reply With Quote
Old 05-03-2020, 10:32 PM   #7
kashup
Kash
It worked!!!
So I used a jack to open it up a little after that used some heat.
Old 05-04-2020, 11:09 AM   #8
ls1ac
ls1ac's Avatar
Use a jack to spread a little wide, use a tape measure, then heat with a torch and let cool with the jack in place.
headers
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
How to properly store your car for winter? Jarrid'sBRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 09-26-2016 10:34 AM
Doing it right ... from the Start, Help me get my FR-S Sorted properly SCIONMONTREAL Scion FR-S / Toyota 86 GT86 General Forum 27 07-09-2015 10:31 AM
How to Properly Data-log?? UrmyboyBLUE Software Tuning 2 10-03-2014 09:59 AM
Always secure your GoPro cam properly :-( Killerbee FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 08-16-2013 02:42 AM
