Old 04-25-2020, 09:52 PM   #1
S0crates
Drives: 2017 BRZ Limited PP
Edelbrock SC ECU Mounting Plate Issue
I am installing an Edelbrock SC into my 2017 Subaru BRZ PP and have an issue with the ECU Mounting Plate. Step #119 of the Installation Guide shows the old ECU just mounting back in place with no issue. However, the instructions are for a 2013-2016 model. My 2017 has the upgraded intake manifold, and the ECU mounting plate has two large tabs with rubber rings which connect to the old intake manifold. These are prohibiting the ECU mounting bracket from being mounted with the new SC intake runners in place. Ideas or suggestions? Are 2017+ owners just cutting the mounts off the ECU mounting plate to make clearance? Perhaps I am missing something
S0crates is offline   Reply With Quote
Old 04-25-2020, 11:57 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
It is hard to tell. Do the tabs slide off?
Old 04-26-2020, 05:06 AM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Slide the rubber grommet out. Afterwards use some pliers to bend the tabs up clearing the supercharger's runners. Far enough up they don't make contact.
Old 04-26-2020, 04:12 PM   #4
snowtaipan
snowtaipan's Avatar
Drives: '17 BRZ Series Yellow Edelbrock SC
I have a 2017 yellow series, I didn't run into that issue. You sure your SC is seated correctly?
Did you already tighten the lower ECU bolt?
snowtaipan is offline   Reply With Quote
The Following User Says Thank You to snowtaipan For This Useful Post:
Irace86.2.0 (04-26-2020)
Old 04-26-2020, 05:34 PM   #5
Irace86.2.0
If not that ^^^ ...Do you have aftermarket injectors or something blocking/lifting the cover?
Old 04-26-2020, 09:16 PM   #6
S0crates
The problem was how the ECU was mounted to the bracket from the factory. Once I removed the ECU from the ECU mounting bracket, the bracket bolted right up with 1-2 mm of clearance to the intake runners without modification. Then, I just bolted the ECU back onto the bracket using the 3 supplied screws.
Thank you for your assistance. The install continues. :-)
The Following 2 Users Say Thank You to S0crates For This Useful Post:
CSG Mike (04-27-2020), Irace86.2.0 (04-27-2020)
License plate mounting 333Matt Cosmetic Modification (Interior/Exterior/Lighting) 6 11-15-2016 07:29 PM
Options for mounting BRZ license plate? gt8613 BRZ First-Gen (2012+) — General Topics 6 10-13-2014 02:12 PM
*GROUP BUY* Rho-Plate License Plate Mounting Kit $40! Massdrop Groupbuys 45 10-15-2013 07:07 PM
rear license plate mounting bracket fiveoneoh Cosmetic Modification (Interior/Exterior/Lighting) 10 03-24-2013 09:35 AM
License plate mounting ideas? csaba Scion FR-S / Toyota 86 GT86 General Forum 1 04-15-2012 09:58 PM
