Old 04-26-2020, 11:25 AM   #1
jaimeFRS
Drives: FRS
Post P0451, P0451, P0453 Fix?
Have a 2013 FRS, when CEL came on for P0451 and P0453. Checked gas cap and drove, then traction off light came on (then P0441). Tried to clear codes but could only clear P0441. Disconnected battery (>4hours) to reset computer but still did not clear the codes. High idle after that.
Thoughts on fix/issue?
If mechanic, anyone have one near the Fairfax, VA area?
jaimeFRS is offline   Reply With Quote
Old 04-26-2020, 03:16 PM   #2
p1l0t
p1l0t's Avatar
That's odd that you could only clear the one code... Whats scanner are you using? I found a nice little EVAP diagram link from @Tcoat on another thread that might be of use.
https://www.ft86club.com/forums/show....php?p=3177367
Old 04-27-2020, 02:18 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Is your car modified? How many miles?
Did you check the fuel cap for a good seal? Is the gasket/o-ring failed, shrunk, etc? Is there an uneven surface leading to a leak?
Check for broken or loose hoses at the EVAP solenoid.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
p1l0t (04-27-2020), Tcoat (04-27-2020)
Old 04-29-2020, 04:01 PM   #4
jaimeFRS
Drives: FRS
Just using a actron pocket scanner, not modified. And I actually replaced the gas cap with a new OEM. Haven't found anything loose either. Only 35k miles
p0451, p0453
P0451 FirestormFRS Issues | Warranty | Recalls / TSB 10 05-03-2023 12:56 AM
P0451 & U1201 after JRSC installation. Thepest Northern California 1 04-06-2020 08:22 PM
P0453 - Anyone Opie Issues | Warranty | Recalls / TSB 10 08-02-2019 11:26 PM
P2097 and P0451 JRSC C30 HBP - EcuTek Tuning dj2020 Software Tuning 5 02-09-2016 03:46 AM
