Old 04-23-2020, 02:16 PM   #29
gpvecchi
gpvecchi's Avatar
FYI, I discovered that there are more types of Performance Package Sachs shocks, while just a type of springs.
Toyota used always the same shocks, that differ from Subaru. Subaru had 2 different shocks set, revised for models G and H (let's say from 2018).
Then there are the Toyota GR and Subaru STi, with specific springs, but this is another story...
The Following 2 Users Say Thank You to gpvecchi For This Useful Post:
nikitopo (08-28-2020), Ohio Enthusiast (04-24-2020)
Old 04-23-2020, 02:47 PM   #30
Ohio Enthusiast
Drives: 2018 BRZ
That's actually very interesting. Do you have the specs for all the combinations for these?
Ohio Enthusiast is online now   Reply With Quote
Old 04-23-2020, 10:24 PM   #31
Espi
Espi's Avatar
Drives: 17 BRZ
I’m actually about to install Sach Dampers and STI pinks tomorrow. I was between rce yellows and STI pinks. Got a really good deal on very low mileage Sachs off a 2019 PP and STI pinks off a 2018 TS. Quick question, are the rear LCAs on the performance package different than the standard models? Or would I be able to just put these right in?
Espi is offline   Reply With Quote
Old 04-23-2020, 10:47 PM   #32
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
The rear LCA's are the same across the range as far as I'm aware. Also, the STI Pinks are not the same as the TS model springs, even though they are also pink. I have the TS springs and dampers also waiting to go on the car.
BlueWhelan is offline   Reply With Quote
Old 04-23-2020, 10:54 PM   #33
Espi
Espi's Avatar
Drives: 17 BRZ
Thanks! Is there any information available on the TS STI pink springs? I’ve recently learned these are not your typical STI pinks. No intention of thread jacking and thank you all again. Timing of this thread couldn’t be any more perfect for me personally lol.
Old 04-24-2020, 02:52 AM   #34
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are the Sachs monotube? I am aware that the standard shocks are a good compromise between performance and cost, but I am not sure about the ones from Sachs. Maybe a bit better than standard while keeping the cost relatively low?
Old 04-24-2020, 04:31 AM   #35
gpvecchi
gpvecchi's Avatar
I'll post later all the part numbers.
Nope, still twin tubes. Better for street, worse for track.
nikitopo (04-24-2020), Ohio Enthusiast (04-24-2020)
Old 04-24-2020, 01:02 PM   #36
gpvecchi
gpvecchi's Avatar
These are the part numbers for PP parts; beside of the P/N all PP springs are marked as 3 blue for front and 1 blue and 1 white for rear:
Toyota:
Front spring: SU003-07194
Rear spring: SU003-07196 (Models E-F, same as non PP)
Rear spring: SU003-08065 (Models G-H, same as non PP)
Front strut R: SU003-06790 (Marked 20310-CA140 on strut, red sticker)
Front strut L: SU003-06791 (Marked 20310-CA150 on strut, red sticker)
Rear shock: SU003-06796 (Marked 20365-CA130 on shock, red sticker)
Subaru:
Front spring MT: 20330CA200 (Same as non PP)
Front spring AT: 20330CA210 (Same as non PP)
Rear spring EU/US: 20380CA210 (Models E, F, G production date 20180101-20180930, same as non PP)
Rear spring EU/US: 20380CA211 (Models G-H from production date 20181001, same as non PP)
Rear spring JP: 20380CA200 (Models E, F, G production date 20180101-20180930, same as non PP)
Rear spring JP: 20380CA201 (Models G-H from production date 20181001, same as non PP)
Front strut R: 20310CA160 (Models E-F, blue sticker)
Front strut L: 20310CA170 (Models E-F, blue sticker)
Rear shock: 20365CA120 (Models E-F, blue sticker)
Front strut R: 20310CA280 (Models G-H, yellow sticker)
Front strut L: 20310CA290 (Models G-H, yellow sticker)
Rear shock: 20365CA240 (Models G-H, yellow sticker)
GR (10 mm lower):
Front spring: 48131-18060 (Made by Chuhatsu)
Rear spring : 48231-18030 (Made by Chuhatsu)
Front strut R: 48510-18040 (Yellow sticker)
Front strut L: 48520-18040 (Yellow sticker)
Rear shock: 48530-18050 (Yellow sticker)
STi/tS 2017+:
Front spring MT: 20330CA260 (Marked 1 light blue and 1 yellow)(Lowered 10 mm)
Front spring AT: 20330CA270 (Marked 1 light blue and 1 yellow)(Lowered 10 mm)
Rear spring US: 20380CA270 (Marked 1 purple and 1 yellow)
Rear spring JP: 20380CA260
Front strut R: 20310CA240 (Model F, green sticker)
Front strut L: 20310CA250 (Model F, green sticker)
Rear shock: 20365CA220 (Model F, green sticker)
Front strut R: 20310CA300 (Models G-H, purple sticker)
Front strut L: 20310CA310 (Models G-H, purple sticker)
Rear shock: 20365CA250 (Models G-H, purple sticker)
Update: reading a Japanese article, I discovered that Subaru added a couple of stabilyzing spoilers behind rear wheels, on the bumper in models G and H, and suspensions have been tuned accordingly. Toyota didn't, that's why Subaru rear shocks have been revised, but not Toyota's.
Update 2: not Sachs, but these are the other OEM specific options.
GRMN:
Front spring: 48131-18050
Rear spring : 48231-18020
Front strut R: 48510-18030
Front strut L: 48520-18030
Rear shock: 48530-18040
tS Model B (2013) (15 mm lower):
Front spring: ST20330AS010 (Marked 1 blue and 1 orange)
Rear spring : ST20380AS000 (Marked 1 white and 1 orange)
Front strut R: ST20310AS000
Front strut L: ST20310AS010
Rear shock: ST20365AS000
tS Model D (2015) (15 mm lower):
Front spring: ST20330AS030
Front strut R: ST20310AS070 (Made by Bilstein, inverted strut)
Front strut L: ST20310AS080 (Made by Bilstein, inverted strut)
Rear shock: ST20365AS030 (Made by Bilstein)
STi Aftermarket spring kit (15 mm lower):
Front spring: ST20330AS000 (Marked 1 white and 1 orange)
Rear spring : ST20380AS000 (Marked 1 white and 1 orange)(same of tS Model B/D)
STi Aftermarket shocks+spring kit (15 mm lower):
Front spring: ST20330AS010 (Marked 1 blue and 1 orange)(same of tS Model B)
Rear spring : ST20380AS020 (Marked 1 blue and 1 orange)
Front strut R: ST20310AS040 (Made by Bilstein, inverted strut)
Front strut L: ST20310AS050 (Made by Bilstein, inverted strut)
Rear shock: ST20365AS020 (Made by Bilstein)
86/BRZ Race coilover, STi and TRD are same kit (made by KYB):
TRD shocks kit MS260-18001 (Yellow color)
TRD springs kit MS250-18001
STi shocks kit 20300AS000 (Silver color)
STi springs kit 20300AS010
I missed the specific Toyota 86 14R60 coilover, as you can't order them, and not suitable for street, with square 14.6K springs!
The Following 15 Users Say Thank You to gpvecchi For This Useful Post:
AndMsc (09-11-2021), BlueWhelan (04-25-2020), CSG Mike (04-24-2020), Drifter X (04-24-2020), Espi (09-06-2021), MrSkubi (07-20-2020), norcalpb (04-24-2020), Ohio Enthusiast (04-24-2020), Prodigalson (09-11-2024), Racecomp Engineering (05-26-2020), radon55 (06-24-2020), solidONE (04-25-2020), Trap63 (07-19-2020), Yoniyama (09-08-2021)
Old 04-24-2020, 01:12 PM   #37
Ohio Enthusiast
Drives: 2018 BRZ
This is wonderful, well done sir!
But I have to ask, what are the model letters? Different build date ranges?
Old 04-24-2020, 02:09 PM   #38
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Toyota:
Front shock R: SU003-06790 (marked 20310-CA140 on shock)
Front shock L: SU003-06791 (marked 20310-CA150 on shock)
Rear shock: SU003-06796 (marked 20365-CA130 on shock)
Subaru:
Rear spring : 20380CA210 (Models E-F-G production date 20180101-20180930, same as non PP, same as models A-D)
Rear spring : 20380CA211 (Models G-H from production date 20181001, same as non PP)
Front shock R: 20310CA160 (Models E-F)
Front shock L: 20310CA170 (Models E-F)
Rear shock: 20365CA120 (Models E-F)
Front shock R: 20310CA280 (Models G-H)
Front shock L: 20310CA290 (Models G-H)
Rear shock: 20365CA240 (Models G-H)
GR (10 mm lower):
Front shock R: 48510-18040
Front shock L: 48520-18040
STi/tS:
Rear spring : 20380CA270
Front shock R: 20310CA240 (Model F)
Front shock L: 20310CA250 (Model F)
Rear shock: 20365CA220 (Model F)
Front shock R: 20310CA300 (Models G-H)
Front shock L: 20310CA310 (Models G-H)
Rear shock: R20365CA250 (Models G-H)
Holy shit thanks for the info dump!!!
Drifter X is offline   Reply With Quote
Old 04-25-2020, 04:23 AM   #39
gpvecchi
gpvecchi's Avatar
Yes, in Japan they are identified as model number, let's say that model E Is built from April 2016, it's the first facelift.
The Following User Says Thank You to gpvecchi For This Useful Post:
Old 04-25-2020, 06:54 AM   #40
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
And that just the Sachs dampers.. I wonder if the CA--- indicates the valving like how bilstein tags their shocks. There a different shock for every version of the sachs equipped cars it seems like.
Intent > Content
Old 04-25-2020, 07:10 AM   #41
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
CAxxx are just increment numbers of the same part. Not related with valving. Our cars were upgraded slightly year-by-year and suspension was improved from time to time too. There were numerous official communications about revised damping and a bit better comfort etc.
Old 04-25-2020, 12:16 PM   #42
solidONE
solidONE's Avatar
Looking at the part numbers used, its probably not. Would have been nice, and you can order a replacement shock based on the valving. Specially when there are so many options to pick from.
I'm currently running a set of 2015 Showas off a BRZ with 2013 BRZ front spring and my factory 2013 FRS rear spring. The ride using the 2015 was better, initially and for a good while. Now that I've some miles on the 2015 Showas, I dont think I can say the same.
I suppose you have to expect that. Oil eventually breaks down, and gas pressure will escape. Its just a matter of how long it maintains performance. It only goes one direction. Gas pressure and oil viscosity is not gonna magically increase with usage.
Intent > Content
FS: Performance Package Sachs Springs and Dampers Desai_N Brakes, Suspension, Chassis 3 01-15-2020 07:12 PM
Looking to purchase 2018 BRZ performance package Sachs mitama Want-To-Buy Requests 0 07-01-2019 12:52 PM
Sold...2017 OEM Performance Package shocks 86MLR Australia Classifieds 7 10-06-2018 01:56 AM
WTB: 2017 performance package Sachs dampers panand Want-To-Buy Requests 1 03-16-2018 02:57 PM
FS; 2017 PP Struts performance package shocks brz sokol Brakes, Suspension, Chassis 3 08-30-2017 09:26 PM
