Old 02-22-2020, 01:51 AM   #15
LancePower
Drives: 2020 BRZ tS
Originally Posted by norcalpb View Post
I’d say it’s closer to a 10mm drop on the JDM STi springs, just like the USDM ones.
Also I believe the USDM STi springs may be softer than your oem TS springs.
Here’s my car on JDM STi springs:
Very interesting info, thank you.
So you think what comes on the 2020 tS are not identical to these?
https://estore.subarupartswarehouse....2010CA000.html
LancePower is offline   Reply With Quote
Old 02-22-2020, 07:29 PM   #16
norcalpb
norcalpb's Avatar
Correct, they are different as they have different part numbers.
The Following User Says Thank You to norcalpb For This Useful Post:
Vides990 (04-24-2020)
Old 04-23-2020, 10:49 PM   #17
Espi
Espi's Avatar
Drives: 17 BRZ
so long story short I’ve been researching for a few months now between STI pinks and RCE yellows for my plain ol 2017 BRZ. I picked up STI Pinks from a 2018 Ts model and sach dampers from a 2019 PP model. This thread is the only one I’ve found on this site with active pics of STI pinks on a non TS BRZ. I’ll be installing it all tomorrow. I’ll post a pic and a review here also.
Espi is offline   Reply With Quote
The Following User Says Thank You to Espi For This Useful Post:
N_Raged (04-24-2020)
Old 04-24-2020, 12:14 AM   #18
HaXx
Drives: jrsc_brz
Originally Posted by JMon85 View Post
Is https://www.vividracing.com/ a legit website/company? Has anyone used it? They sell the pinks but i never heard of this site until now.
vivid racing is probably THE MOST legit aftermarket retailer
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 04-24-2020, 04:29 AM   #19
gpvecchi
gpvecchi's Avatar
tS Pink are different from aftermarket ones. They don't lower the car, furthermore they are not compatible with PP dampers, as tS dampers are specific and more stiff...
Old 04-24-2020, 05:14 AM   #20
JIM THEO
Drives: BRZ 2018
I wonder as STI pinks (JDM aftermarket ones) are stiffer even than tS pinks, how can they be compatible with the normal BRZ shocks and NOT with the BRZ STI models shocks?
STI pinks:
Front springs rated at 50N/mm, approximately 5kgf/mm (~95% proportional ratio)
Rear Springs rated at 40N/mm, approximately 4kgf/mm (~70% proportional ratio)
Lowers the vehicle approximately -15mm
JIM THEO is offline   Reply With Quote
Old 04-24-2020, 07:17 AM   #21
Espi
Espi's Avatar
Drives: 17 BRZ
I figured Ts springs were a little stiffer considering the specs of the Ts dampers. I didn’t think it would matter as there are countless posts of ppl running PP Sachs with swift spec r. Those maybe one of the stiffest springs available. Are the Ts springs stiffer than swift spec rs? Doesn’t make sense to me they wouldn’t be compatible for pp Sachs. I’ve seen the catalog disclaimer and have standard shocks as a fall back if the balance is really bad. Not to doubt your comment just sharing my thoughts on getting these springs. If anything I can always order the RCE yellows I guess. Still plan to see this out once and for all.
Should be an interesting day. Lol
Old 04-24-2020, 11:42 AM   #22
gpvecchi
gpvecchi's Avatar
STI pinks:
This is what Nengun says, but it's wrong, as not related to BRZ springs, but some other STi springs. The correct rates are not given for STi, and rear are stiffer than fronts.
The Following User Says Thank You to gpvecchi For This Useful Post:
norcalpb (04-24-2020)
Old 04-24-2020, 11:52 AM   #23
Espi
Espi's Avatar
Drives: 17 BRZ
Installed Ts STI Pinks on sach dampers successful. No fitment issues, initial feel is positive so far. It drives smooth and feels just a hair stiffer than full stocks. Also feels like I have more grip. On my way for alignment now.
Old 04-24-2020, 03:48 PM   #24
norcalpb
norcalpb's Avatar
Do you know if the spring bias was moved more towards the front for the 2017+ lowering springs? I believe my JDM STi springs are 175f/225r based on quick Norcalpb math. I felt a strong need to get the Mann 13mm rear bar to balance it out and it certainly did the job, but I’d be interested in the newer STi lowering springs if they were closer to even front and rear.
Old 04-25-2020, 12:26 PM   #25
Espi
Espi's Avatar
Drives: 17 BRZ
Alright so overall STI Pink off a 2018 Ts fit Performance package dampers off a 2019 BRZ. Height measurements floor to center wheel well before on full 2017 limited stock suspension rear sat at 26.6 inches off the ground and front at 26.3 inches off the ground. After install and realignment. Rear now sits at 26.2 inches and front at 25.9 (on stock 2017 wheels 17x7 - 225/45/17)
Suspension feels slightly stiffer than stock and provides more grip overall. Balance was not lost and still feels like oem handling. I’d say the handling/feel leans more towards a sport setup now than a more 50/50 approach of comfort and sport. Maybe now more Sport 60/comfort 40. I can however feel a rear sway bar may enhance more stiffness in the rear while cornering. Cornering is still sharp and planted just the rear feels a hair softer when cornering (maybe the Sachs) still very confident in the cornering ability and none was lost. Just can feel a rear sway may aid some stiffness for cornering.
Overall I am happy with this setup it’s a very mild move towards a more sporty setup. Doesn’t require any supporting mods like a rear LCA or anything and the stock handling characteristics are still retained. I’m happy with it as a daily driver but won’t rule out in the future of possibly going with RCE yellows.
Pics avail on my Instagram at brzespi for now ill upload some here later when I have more time
norcalpb (04-25-2020)
Old 04-25-2020, 03:31 PM   #26
Espi
Espi's Avatar
Drives: 17 BRZ
Maybe I'm a rebel with my setup. I have an Auto 2017 BRZ, on PP Sachs off a manual with STI Pinks from a Ts. lol - The more seat time I get the more I am loving this setup.
The Following 4 Users Say Thank You to Espi For This Useful Post:
BlueWhelan (04-25-2020), norcalpb (04-25-2020), Racecomp Engineering (04-25-2020), solidONE (04-27-2020)
Old 04-25-2020, 04:50 PM   #27
LancePower
Drives: 2020 BRZ tS
So it sounds like the USDM tS Springs may offer a small amount of lowering.
What's that like 8mm?
Depending on how long those tS Springs were actually installed on the prior car, might get down to 10mm to match the advertised drop of the dealer option STI Springs.
Old 04-25-2020, 04:57 PM   #28
norcalpb
norcalpb's Avatar
[IMG]Maybe I'm a rebel with my setup. I have an Auto 2017 BRZ, on PP Sachs off a manual with STI Pinks from a Ts. lol - The more seat time I get the more I am loving this setup.
My favorite thing about the STi springs is they are soft enough where your headlights don’t bounce up and down at night. I swear every lowered 86 that I pass/passes me on the highway at night has its headlights bouncing up and down on every little bump they hit.
STI Pinks Springs ZC6BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 11-22-2022 09:33 PM
STI Pinks? mcbrawr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-26-2016 03:32 PM
WTB: RCE or STI Pinks Springs Mr.Impreza Canada Classifieds 0 02-14-2016 01:11 PM
STI pinks ~ Looking for pics/suggestions Mr.Impreza Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-31-2015 06:59 PM
WTB: STI Pinks eddieEndo Want-To-Buy Requests 0 02-06-2014 05:26 PM
