Old 04-12-2020, 03:26 PM   #29
Ashikabi
Ashikabi's Avatar
Your brake pedal is a rock because your vacuum pump failed.
...but you should do the engine swap just to be sure.
This vacuum pump thing is new to me. Does the FA20 not pull enough on it's own?
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-12-2020, 05:16 PM   #30
Something about the automatic. Can't use manifold vacuum for the booster so it has that cam-driven vacuum pump.
Old 04-12-2020, 05:18 PM   #31
Ashikabi
Ashikabi's Avatar
Only the automatic though?
Old 04-12-2020, 05:23 PM   #32
Yeah. Manual gets that leaky blank-off plate
Old 04-12-2020, 08:24 PM   #33
kev0
Drives: '14
Originally Posted by DJ92 View Post
I was actually gonna ask, was looking through it and didn't see it. THANK YOU for the help I'm really thinking this is it. My brake pedal is also a rock and sounds like that's another symptom. I'm ordering the part and I'll install when I get it and definitely update
My money is on the vacuum pump. All symptoms point to it. Automatic Transmission, ticking noise from back passenger side, RPM's dropping low enough to the point where it almost dies before shooting back up.. The part costs like $150 and will be like a 30minute to 1 hour job.
Get it fixed and let us know if that was the problem.
kev0 is offline   Reply With Quote
Old 04-13-2020, 03:24 PM   #34
potter
Drives: scion frs
ii'm having a similar issue and sound like in second vid. like loud rattle knock when reeving or increase of RPM.
potter is offline   Reply With Quote
Old 04-14-2020, 05:50 PM   #35
DJ92
Drives: 13 Crystal Black Silica BRZ
If I could I'd just swap in a ls 😁
If it's an auto it could be, just check everything out like I did
Part should be here end of the week or beginning of next, got my fingers crossed!
DJ92 is offline   Reply With Quote
Old 04-17-2020, 03:58 PM   #36
DJ92
Replacing the vaccume pump did absolutely nothing. It is doing exactly the same thing. I have no clue what is wrong becides something inside broke. I do know this was not the vacuum pump
Old 04-17-2020, 04:06 PM   #37
Ashikabi
Ashikabi's Avatar
Well, that sucks. Drop in a used motor from the same year and hope for the best. That's the cheapest option.
Old 04-17-2020, 09:24 PM   #38
DJ92
After much debating I'm saving up 4k and doing a manual swap.
Old 04-17-2020, 10:01 PM   #39
What about your brakes?
Old 04-17-2020, 10:24 PM   #40
Trade the car for a manual. Doing a swap is just ripping your money up into little pieces and setting it on fire.
Old 04-18-2020, 08:09 AM   #41
kev0
Drives: '14
Dang. Well how much do you want for the old vacuum pump then? I can buy it off you.
Old 04-18-2020, 10:40 AM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have all the parts he needs minus the engine..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
bearing, broke, engine, knocking, motor
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 08:12 AM
Need advice, dealership says I need new engine spdsk8race Issues | Warranty | Recalls / TSB 22 04-11-2018 02:23 PM
Need some advice on engine guys! dsteezy86 Northern California 23 01-19-2017 07:33 AM
Engine noise... advice? hyperpunx Issues | Warranty | Recalls / TSB 8 09-28-2012 12:57 PM
