Old 04-17-2020, 08:01 PM   #1
MilkyWitness
Drives: fdsgh
Where can I find door speaker mounts/brackets?
asdf
MilkyWitness is offline   Reply With Quote
Old 04-17-2020, 08:55 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
these look to fit.
crutchfield is really conservative. when they say that something fits, it usually does. though i haven't run across anyone that has used these brackets.
https://www.crutchfield.com/p_142SAT...-Brackets.html
otherwise, you can make your own out of any malleable material. i've watched one youtube car audio guy that uses 1/2" thick black ABS sheets for any adapters/bracketry he needs.
other guys will use plywood of varying extreme degrees of moisture resistance-- which appears to be directly related to how paranoid they are someone's tapped their phones...
i generally use HDF or MDF, in 3/4"(or closest) thickness, and then violently attack it with a router and a sharp bit (ok, i trace the outside perimeter oem speaker pattern onto it, and then trace the cut-out size of the replacement within that). i always follow up by painting it with whatever spray paint i have nearest to sort of seal it from the elements, though i usually try to use black paint so it doesn't stand out behind the door card.
Old 04-17-2020, 09:15 PM   #3
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
these look to fit.
I can vouch for these brackets. I bought them from Crutchfield.
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
soundman98 (04-17-2020)
Old 04-18-2020, 06:45 AM   #4
MilkyWitness
Drives: fdsgh
these look to fit.
Thanks for the link! I found a thread on the legacy forums on making a bracket from a cheap cutting board:
https://legacygt.com/forums/showthre...rs-175931.html
I might try and tackle the cutting board procedure
Old 04-18-2020, 04:48 PM   #5
gpvecchi
gpvecchi's Avatar
I bought specific ones from Japan...
Old 04-18-2020, 06:50 PM   #6
MilkyWitness
Drives: fdsgh
Helpful
Old 04-18-2020, 07:51 PM   #7
soundman98
soundman98's Avatar
were they overnighted?
Old 04-18-2020, 10:16 PM   #8
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Is this one of the tell-us-and-you-have-to-kill-us deals or.....?
sharpsicle is offline   Reply With Quote
The Following User Says Thank You to sharpsicle For This Useful Post:
soundman98 (04-18-2020)
Old 04-18-2020, 11:55 PM   #9
soundman98
soundman98's Avatar
are japanese brackets made of titanium or something that's inherently less prone to vibration, but sound better?
Old 04-19-2020, 04:49 AM   #10
gpvecchi
gpvecchi's Avatar
Only JDM for me.
Old 04-19-2020, 12:31 PM   #11
sharpsicle
sharpsicle's Avatar
Only JDM for me.
JDM doesn't automatically mean better.... What did you buy?
Old 04-19-2020, 05:23 PM   #12
In 99.9% of the time the "JDM" parts are exactly the same as the rest of the world parts. There are very few things that are truly "JDM".
Doesn't help that everybody thinks JDM means something totally different than it really means either.
sharpsicle (04-19-2020)
Old 04-19-2020, 08:44 PM   #13
RRslip
Drives: Black BRZ - STX
If you make your own brackets use .75" MDF for the doors and .25" MDF for the tweeters, both are available in 2'x4' sheets at home depot. Use a jig saw to cut them out. OE parts are very easy to trace. This platform is super easy to work on. If you are into car audio, learn to make your own brackets. Also, your sound will greatly improve if you use some thick foam padding and ensure a lot of interference between the foam and the extrusions on the door panel.
RRslip is offline   Reply With Quote
The Following 2 Users Say Thank You to RRslip For This Useful Post:
soundman98 (04-19-2020), Tcoat (04-19-2020)
Old 04-21-2020, 05:21 AM   #14
MilkyWitness
Drives: fdsgh
Where did you get the foam roll? Home Depot?
WTB: STI Short Throw Shifter, Hitch, front door speaker mounts MilkyWitness Want-To-Buy Requests 5 05-15-2020 12:14 AM
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. The Sentinel DIY (Do-It-Yourself) Guides 3 01-28-2016 06:39 PM
FS Buddy Club seat mounts with sliders and side mount brackets. irax Interior Parts (Incl. Lighting) 0 03-05-2015 10:19 PM
FS: PVC Door Speaker spacers / brackets for 6.5" speakers Kayzer Soze Audio/Visual, Electronics, Infotainment, NAV 1 08-25-2014 10:05 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
