Old 04-16-2020, 12:32 AM   #1
86_jc
Drives: 2014 frs. Asphalt grey
Need help. Shifter prob
So I just installed a short throw from ft86 (their version.) and it has a sort of “swivel” or “rotation” in it. Everything is fine it just had that weird thing that’s makes it feel off. I added video of the problem. Any advice on fixing the issue ?
86_jc is offline   Reply With Quote
Old 04-16-2020, 12:32 AM   #2
86_jc
I lied this the link to a yt vid of the issue
Old 04-16-2020, 09:47 AM   #3
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
https://www.ft86club.com/forums/showthread.php?t=125248
This has been an issue since they released this product. I linked a thread above. There is a set screw that is supposed to keep arm and ball secured, but in your case it has either backed out or is stripped.
The other issue with this shifter is the reverse lockout will strike the bolts securing the plate.
FT86 Speed factory should not be selling this product. You are better off getting a refund and buying the STi part.
tehShirt is offline   Reply With Quote
The Following 2 Users Say Thank You to tehShirt For This Useful Post:
Decep (04-17-2020), humfrz (04-16-2020)
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 08:38 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
