Old 04-13-2020, 01:10 AM   #1
Arthur_frs
Drives: 2013 FRS
Limp mode at 2K rpm NEED HELP!!
Hello guys, just purchased a 2013 FRS, drifted it for 40 min and then went to limp mode, I start up the car it’s fine until I turn to the right and then goes into limp mode again. I ran the codes I’m getting a EVAP system code. I have cleaned the MAF took off the manifold checked for any loose hoses etc everything is in place I really need help.
Keep in mind this car is a “drift build” has no AC no TC and no ABS it has been removed
Codes I got
P0453
P2419
Arthur_frs is offline   Reply With Quote
Old 04-13-2020, 07:31 AM   #2
Ashikabi
Ashikabi's Avatar
Might as well remove the evap too. Have to turn off the code in the tune though
Sent from my ONEPLUS A5010 using Tapatalk
Old 04-13-2020, 10:06 PM   #3
Arthur_frs
Drives: 2013 FRS
Bump really need help
Old 04-13-2020, 10:06 PM   #4
Arthur_frs
Drives: 2013 FRS
Where is it exactly
Old 04-13-2020, 10:08 PM   #5
Ashikabi
Ashikabi's Avatar
Originally Posted by Arthur_frs View Post
Where is it exactly
Canister is above your differential. You can just unplug from engine and turn off codes though. Might have to plug up some holes to avoid vacuum leak. If it's a half stripped drift missile there's no point in maintaining emissions equipment
Old 04-13-2020, 10:22 PM   #6
Ashikabi
Ashikabi's Avatar
Where is it exactly
Interwebs is telling me there may be something amiss with your vacuum pump. Check all your hoses and wiring on the back of your motor
Limp mode GTBOY Issues | Warranty | Recalls / TSB 4 06-07-2018 12:58 PM
Valet mode / limp mode? radroach Software Tuning 1 09-18-2017 11:34 AM
How to limp mode.. vichiball Software Tuning 5 07-12-2016 01:18 PM
Limp mode AFTER clearing CEL white_knight Issues | Warranty | Recalls / TSB 8 03-30-2016 08:40 PM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
