Old 04-12-2020, 11:59 AM   #15
coconutboy
coconutboy's Avatar
Drives: 2015 White BRZ Aozora
Thanks for the insight guys. I think I might go the rocketbunny route. Or custom widebody. You're right guys, the brz is more of a momentum car and corner specialist, not straight line. I'm running falken fk510's and the airlift struts are just BC coilovers with bags over them, so I have 32 way adjustable dampening. Going to get stiffer anti sway bars too. But aside from an intake, are there any other bolts ons that are low risk in terms of reliability issues and good reward? Name:  PSX_20200411_224114.jpg
Sent from my SM-G950W using Tapatalk
coconutboy is offline   Reply With Quote
Old 04-12-2020, 12:00 PM   #16
coconutboy
coconutboy's Avatar
Crap I didnt know I had 2 different accounts! Disregard the different handles.
Old 04-12-2020, 12:10 PM   #17
WNDSRFR
Drives: FR-S,GTI
Originally Posted by thomasmryan View Post
great vid...notice he stays above 5k.
dude is Fangio reincarnated.
Buy a used Phantom ESC. Then you will be shifting at 5k. Because the power band is between 3k and 5k. It's just what the doctor ordered. Completely transforms your driving habits.
Read the ESC thread. It should only take you a couple weeks.
You aren't going anywhere anyway are you?
Old 04-12-2020, 02:05 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't see any reason for stiffer sway bars, and the gains from changing the airbox are 'butt dyno' improvements at best. i believe most claim 5-8hp, which amounts to a minor elevation change..
gone are the days of bolting on 50 hp airboxes. the oem's don't design them that terrible anymore.
my suggestion is to enjoy the car for what it is.
Old 04-12-2020, 02:15 PM   #19
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
no need. I am into more technical type lateral stuff and quite satisfied with stock. my first mod, if any, would be LCAs to take out some rear camber back to 1 or 1.1 degrees.
pull up where I live and look at highway 32, clingmans dome road, little river rd and, of couse, the dragon. I use 2nd and 3rd mostly and 4th is good to 108 or so. I use 5th and 6th maybe ten times a year.
thomasmryan is offline   Reply With Quote
Old 04-12-2020, 03:20 PM   #20
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Solution:
Take your mod money, get a cheap reliable beater car.
Then take the leftovers and you can do whatever you want without worrying about opinion.
If I have any questions about reliability or performance for a car I drive on a daily basis (especially for work or critical things), I keep it simple. My current fun car has been sitting in the garage for months because I'm too lazy to fix my suspension bushing issues (and the "fix" I came up with was to buy KW V3...)
Old 04-12-2020, 03:22 PM   #21
JD001
JD001's Avatar
Drives: Subaru BRZ
Delete, delete, delete, delete... Oops!! Wrong thread...
Old 04-12-2020, 03:28 PM   #22
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Spend 40k on a car worth 13.....
TommyW is offline   Reply With Quote
Old 04-12-2020, 03:50 PM   #23
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
I love how your car looks. Super simple and clean. Did you pick up the wheels used? What power mods do you have now?
I would just keep it as it is with just little “bolt on” mods. Maybe e85 if available. Upgrade the suspension with quality parts. Keep nice and simple.
You can go either direction, but I personally would go boosted if I had to pick. Tons of people have gone FI with no issues. Just gotta be smart about it. Widebody is cool, but somewhat overdone. It’ll slow you down like you said and would really only be for show. If you kept the car as it is looks wise, it would be a bit of a sleeper. Your choice though.
Getting a beater daily is also a good idea given your commute. That way, if you have issues with the BRZ, you have something reliable to get around. Keep in mind that less is more and there’s no coming back after you start cutting the car up lol Good luck and nice car!
Will BRZ is offline   Reply With Quote
Old 04-12-2020, 04:07 PM   #24
coconutboy
coconutboy's Avatar
Thanks man it's actually a series blue so exterior is stock. I spent 7 grand on my suspension and I'm getting cooked in the thread saying I should get better suspension however I wanted new sway bars so my car is more flat in corners but I'll look into ESC. Only power mods that are done is full exhaust system with an OFT tune to stage 2+. Any thoughts on power blocks. Crawford says 19 hp but it's only like $250. I call bullshit, but it's also Crawford so I have no idea what to believe. I dont want a beater I live with mommy and daddy I'm 22 going on 23.
Old 04-12-2020, 04:09 PM   #25
coconutboy
coconutboy's Avatar
LOL the phantom esc is not what I thought it was gonna be LOL I think I got trolled
Old 04-12-2020, 05:05 PM   #26
soundman98
soundman98's Avatar
you've misunderstood. you threw $7k into suspension for a specific functionality. you did not spend $7k on better performing dampers.
this is no different than anyone else bragging about saying they bought a $90k lexus, and then complaining when people say that a $40k lotus will be able to out-handle it.
suspension is voodoo, wrapped in an enigma, coated in big words. $7k would have gotten you really close to this, had you spent it on spring and damper upgrades instead of an air tank and compressor.
https://www.ft86club.com/forums/showthread.php?t=139592
sway bars don't fix the suspension though. there's been a couple threads on this, and all of them end up saying very similar things. stiffer sway bars tend to be a bandaid. they fix the problem of the car rolling, but at the cost of making the car bouncier on wheel hits. if you're interested in being fast/performance-based, sway bars aren't the answer.
power blocks move the power curve around. they do offer a slight bump, but it's not significant. it's heavily dependent on how you use the existing power curve.
https://motoiq.com/tested-crawford-p...old-spacers/3/
you wanted to discuss more power, i don't see how that's trolling...
Old 04-12-2020, 05:10 PM   #27
soundman98
soundman98's Avatar
i think the main problem here is that you're trying to make the car into a 'do-all' swiss army knife of cars.
cars CAN'T do it all.
you can have a track-focused monster, but sacrifice streetability in the process.
you can have airbag suspension to adjust the ride height, but it'll never handle the same as a car with proper springs and progressive dampers.
you can't have a boost in power without some hit on reliability in some way.
and lastly, you're 23. save your money for more important things. i can bet you that you're not going to keep this car more than 10 years at best. history is in my favor.
Old 04-12-2020, 05:27 PM   #28
coconutboy
coconutboy's Avatar
Love the reply thanks for the detailed response
Sent from my SM-G930F using Tapatalk
boost, power, reliability, widebody
3 way Component Set - AMP of Head unit power? HeresMyMind Electronics | Audio | NAV | Infotainment 4 02-04-2020 03:44 AM
This hurts my soul... lupindub Other Vehicles & General Automotive Discussions 56 01-26-2016 02:55 PM
Ouch this hurts. uEih BRZ First-Gen (2012+) — General Topics 42 06-02-2015 03:09 PM
Need help.. Pioneer head unit after power restored Skurj CANADA 4 04-06-2014 02:03 PM
Winter hurts. Superhatch BRZ First-Gen (2012+) — General Topics 33 02-07-2013 08:29 PM
