#29 | |
I'm still on my original engine; the 12.5:1 compression I mention is stock in my case. In fact, the engine itself is still 100% stock and OEM. |
#30 | |
Software Hobbiest
Drives: 2015 FRS
Can I ask what boost your running, and is your cam Maps the OFT set or the TommBRZ cam Maps |
#31 |
#32 | |
Rust bucket enthusiast
This is on 93 octane. |
#33 | |
Drives: brz
I also remember you saying you also slowed your spool down?. So just limit your boost to 7 lbs until 7000rpm then up it to 20lbs, then you have a reliable 500. |
#34 | |
![]() Spool is not slowed down. Rather, I have rising rate boost. |
#35 | |
Drives: Q5 + BRZ + M796
--Increasing pressure increases heat a lot, and it is in a non-linear way, so higher compression can lead to knock, which limits boost potential or makes it necessary to reduce timing a lot. --I have heard that high compression/low boost means there is less manifold pressure wanting to inject air into a cylinder that is a smaller space versus low compression/high boost where there is a lot of manifold pressure which pushes a lot of air into a bigger cylinder.
#36 |
That seems aggressive. My Harrop kit is hitting around 12-12.5psi, and Zach Tucker wasn't too happy with me running 91; he thought it was too much boost for 91. I have E85 now. The car is happier.
#37 | |
#38 | |
Drives: 2017 toyota 86
On 12.5-13psi on my failsafe 92 map i still have a decent amount of timing although I’m probably right at that limit where more boost is pointless maybe even already a little beyond the limit, i would need to dyno comparison to know for sure. With my WMI i probably have a little bit more headroom left as i can safely run a bit more timing and obviously cooler IAT helps a lot too. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Irace86.2.0 (04-10-2020) |
#39 | |
I think what he is trying to say is that his torque curve/boost rises across the rpms like a JRSC. If he is tracking it a lot and staying high in the rpms then such a setup would not hinder performance, but the benefit would be better reliability around town. Too much torque down low seems to be a recipe for rod failure. This with a lower boost level in low gears seems best.
#40 | |
#41 | |
As boost increases heat exponentially increases once it hits the tipping point of the octanes abilities you start pulling exponentially more timing, and like I mentioned the inherent risks of running more boost increase, so it’s recommended to not just throw all the boost at it even if you technically “could”. Hypothetically, Say going from 8 to 10psi you drop from 19 degrees timing to 17 degrees timing. Say 1 psi is 4% whp, 1 degree of timing is 2% whp so you still have a net gain of 4%, but say the “threshold” of 91 is at 10psi, meaning going from 10-12psi your timing to not have knock goes from 17 to 13 degrees. 8% gain from boost but 8% loss from timing so You gained no power, but now have the added risks and increased temps of more boost for no benefit. Then you go 12-14psi but timing goes from 13 degrees to 5 degrees. And now you just lost power. As you see because the heat increase is exponential so is the timing being pulled to accommodate. This is why it’s technically possible to run say 14psi with 91 but highly not recommended, and running 10psi would be ideal as you make max power still, but still have some safety wiggle room for error/increased temps from driving hard, at 12psi you still make peak power but with basically no wiggle room. And at 14 psi you might actually lose power and have zero wiggle room. So the ideal “threshold” of the octane is when you can still make max power but at the lowest boost level for highest margin of error. And if you drive hard like tracking that threshold decreases because your temps will obviously be a lot higher. |
#42 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Irace86.2.0 (04-10-2020) |
| Tags |
| 500 whp, 550 whp |
| Who makes a good AOS for our cars? | D K | Engine, Exhaust, Transmission | 17 | 05-28-2014 04:24 PM |
| GReddy Scion FR-S Makes First USA Public Appearance at Cars & Coffee in Irvine, CA | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 01-16-2014 02:28 AM |
| How do I use A2DP conveniently and reliably? | qoncept | Electronics | Audio | NAV | Infotainment | 6 | 06-04-2013 01:35 PM |
| Got a ride in a 550hp C5 Vette...meh. | Superhatch | Other Vehicles & General Automotive Discussions | 8 | 11-06-2012 03:32 AM |
| Aftermarket hood supports | fasteddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-14-2012 12:01 AM |
