Old 04-08-2020, 08:15 AM   #1
paulca
Drives: Toyota GT86 Coupe Red (UK)
"Clacking" noise left side cylinder head side.
I'm hoping this is just coming from one of the auxillary bits like the air con compress or the brake distribution box, but can anyone verify?
The video starts on the quiet side (UK drivers side) where the engine sounds fine, then moves to the side which has a metallic "clack" tappet like noise.
Also, as a bonus, here is the engine in thermal IR.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 04-08-2020, 11:32 AM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The complex device with all the hard tubing over the left front cylinders is the High Pressure Fuel Pump.
Yes. That's the cricket cage.
Old 04-08-2020, 11:55 AM   #3
bobel
Drives: GT86
Would be inclined to agree, sounds like it is the high pressure fuel pump chirping away.
The high pressure fuel rail on the right (UK Drivers side) which that pump also feeds has a pressure sensor on it, if your pump is under delivering I would imagine you’ll see a code thrown from the ECU pretty quickly.
As said above the HP pump runs off a cam lobe and is located just under the three fuel hoses, if you can confirm that’s the exact location of the noise than it’s the source and I would not be inclined to be too worried about it in that case.
bobel is offline   Reply With Quote
Old 04-08-2020, 12:02 PM   #4
paulca
Just to be clear as "left and right" are a bit messed up with the video as I'm looking at it from the front
In the video the left side is the side with the dip stick and the right side is the side with the oil filter and oil filler cap.
The left side sounds like a nice click-ity-click of valves and injectors. The right side has a harsher "clack" noise that seems to be twice the valve frequency, but it could two valves clicking. Loudest right down between the air con pump and the oil filter.
Old 04-08-2020, 12:14 PM   #5
bobel
Drives: GT86
The HP fuel pump is just behind the oil filter, you can see the top of it in the photo below, located just under the fuel lines. The standard black steel shield may block your view. I have removed it on my racecar.
Old 04-08-2020, 06:24 PM   #6
Due to isolation, I suspect you are just hearing things that don't matter.
Old 04-09-2020, 01:21 PM   #7
paulca
I'll assume it's the fuel pump, thanks. It's not really bothering me, just thought I'd check with you guys though.
Old 04-09-2020, 08:25 PM   #8
Ashikabi
Ashikabi's Avatar
My fuel pump made all kinds of noises. Don't worry about it
Sent from my ONEPLUS A5010 using Tapatalk
Nagisa Auto "D-LOCK" Super Low Seat Rail (Driver's side) Kestrel Interior Parts (Incl. Lighting) 10 06-18-2018 02:21 PM
Anyone try to retrofit the "Series Blue" air splitter and side skirts yet? FloridaFRSdriver Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2015 09:48 PM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 03:43 PM
"clacking" noise near tranny area? QckFR-S Issues | Warranty | Recalls / TSB 24 05-11-2014 12:33 AM
Metallic "Clacking" Noise Killians87 Issues | Warranty | Recalls / TSB 9 04-30-2014 12:40 PM
