Old 04-06-2020, 08:15 PM   #1
guajar01
Drives: 2015 Scion FR-S
255/35 r18 Rubbing rear fender.
I just recently installed some coilovers along with rear LCAs and some new rims with tires. The rims are 18x9.5 +35 wrapped in a 255/35 r18. I am able to fit 2 fingers underneath the rear fender but I am still getting a little rub. Anyone have any suggestions on what I could do to remedy the rub issue? The LCAs I have are blox and I did take note that the bolt that connects to the hub is on the hole of the top of the LCA.
guajar01 is offline   Reply With Quote
Old 04-07-2020, 10:50 AM   #2
Grady
Grady's Avatar
Buy tires and wheels that fit.
The Following 2 Users Say Thank You to Grady For This Useful Post:
JD001 (04-07-2020), NoHaveMSG (04-07-2020)
Old 04-07-2020, 10:51 AM   #3
Camber
Old 04-07-2020, 11:02 AM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
Since you have coilovers, you can lift a bit. And give more camber if possible.
There is a specific subforum for such questions, I would ask @Leonardo there.
The Following User Says Thank You to mrg666 For This Useful Post:
Leonardo (04-07-2020)
Old 04-07-2020, 12:04 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If your LCA are installed the same as this picture, I think that is correct. -3 camber in the rear should be enough. What are you running now? Also, did you preload the coils to spec? My 18x9 +27 rear has 1.7mm more of poke than a 18x9.5 +35. The stretch of a 255 on a 9.5 should be similar to my 245 on my 9.
Not all tires are equal to the numbers on them. Meaning some are wider than others in the same size. What tires are you using?
via Imgflip Meme Generator
I LIKE TIRES!
Old 04-07-2020, 12:14 PM   #6
guajar01
My LCA setup is exact to the picture you have. My rear camber is set at 3.1, my tires are the falken azenis fk510 . My preload is at factory setting on both front and rear. I’m on flex z
Old 04-07-2020, 12:17 PM   #7
guajar01
Old 04-07-2020, 12:21 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Edit Pics just loaded. My connection must be slow...
You need more camber.
I LIKE TIRES!
Old 04-07-2020, 12:37 PM   #9
guajar01
My bad -3.1. The coils where preloaded already but I’m now thinking I may have to adjust them a little now that you mention it
The Following User Says Thank You to guajar01 For This Useful Post:
Old 04-07-2020, 12:56 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My FA500 did not arrive in the box properly preloaded. I had to adjust them myself. I would inspect them to make sure they are. -3.1 looks really close to not rubbing.
I LIKE TIRES!
Old 04-07-2020, 12:58 PM   #11
guajar01
I’ll definitely give it a try. I appreciate the advise. Hopes this remedy’s the issue.
Tire Rubbing Fender Liner Help Pizzachicken Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 12-04-2018 09:59 AM
Fender rubbing issues amaciose Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-29-2016 12:30 PM
17x9 +45 rubbing fender liner with coilovers nomis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-13-2016 12:41 AM
Drift alignment. rear toe problem and front sway bar rubbing trdric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-03-2015 01:21 AM
Rubbing fender. dito Southern California 34 05-15-2015 01:12 AM
