Old 03-30-2020, 01:40 AM   #1
AjSingh
Drives: Scion FRS ‘13
Headers & OverPipe
Hey guys, I’m new so I apologize if I make any mistakes in posting on the forums. I have a 2013 FRS, recently I installed headers, which followed by a clunking sound, it looks like my overpipe is hitting my frame. I’ve tried wrapping the overpipe in heat wrap to soften it up, it lasted for about a week and the clunking noise is back there again. At this point idk what to do whether to go back to stock headers or get a different overpipe for the car. Any recommendations or advice?
AjSingh is offline   Reply With Quote
The Following User Says Thank You to AjSingh For This Useful Post:
Joveen (03-30-2020)
Old 03-30-2020, 07:36 AM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Put a dent in that overpipe.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 03-30-2020, 11:29 AM   #3
LancePower
Drives: 2020 BRZ tS
What Header is it?
LancePower is offline   Reply With Quote
Old 03-30-2020, 11:59 AM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
What's the header and overpipe you have installed? Maybe try unbolting them and seeing if you can adjust it up a little.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
JohnJuan (04-08-2020)
Old 03-30-2020, 12:32 PM   #5
Tokay444
How many headers did you install?
The Following User Says Thank You to Tokay444 For This Useful Post:
NWFRS (04-04-2020)
Old 03-30-2020, 12:34 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stiffer motor mounts are the common fix. Not always a guarantee, sometimes shit just don't quite fit right.
Old 03-31-2020, 03:54 AM   #7
AjSingh
The engine does seem to shake a bit, & the noise does go away if i press down on the engine. Do you have any mounts you recommend?
Old 03-31-2020, 03:56 AM   #8
AjSingh
I don’t actually know the brand. It was a gift from a friend. I plan on trying to adjust them, if it doesn’t work, I think I might plan on going back to stock overpipe just so I can stop the clanking.
Old 03-31-2020, 11:33 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The STI mounts are a common upgrade. They are stiffer than stock, but not overly so.
Old 04-04-2020, 12:02 PM   #10
saltywetman
Drives: 2020 Toyota 86 GT 6M
do all header upgrades typically require aftermarket engine mounts?
saltywetman is offline   Reply With Quote
Old 04-04-2020, 03:48 PM   #11
weederr33
weederr33's Avatar
No. The only one I've heard that people insist needing is the ACE. I find it rather ironic that aftermarket headers would need up-rated motor mounts considering they're supposed to be lighter than the stock manifold.
saltywetman (04-04-2020)
Old 04-08-2020, 04:46 PM   #12
Ernest72
No but some hit the aluminum under tray. I had to bang mine a bit and I also put a spacer washer in the front to get the tray a few mm lower to not rub on the header.
Old 04-08-2020, 05:15 PM   #13
CSG Mike
CSG Mike's Avatar
It has nothing to do with weight. It has to do with the massively larger dimensions of the header compared to stock.
nikitopo (04-09-2020), Qadthane (04-08-2020)
Old 04-08-2020, 05:28 PM   #14
weederr33
weederr33's Avatar
Sounds like a design flaw!!!
Kidding. This cooping up is making me irritable. But that makes sense. Still, outside the a couple exhaust pieces, I've never had a fitment issue.
WTB Headers and 3" Overpipe Ignore Your Doctor Want-To-Buy Requests 0 05-27-2019 12:56 AM
MXP Un-Catted UEL Headers with Overpipe (Toronto) Sweet48 Canada Classifieds 2 09-15-2017 12:18 AM
FS: Brand New MXP UEL Headers w/ Overpipe Subaru86 Engine, Exhaust, Bolt-Ons 7 09-21-2015 12:50 PM
FS (NC): New Tomei EL Headers and Overpipe THEmailman Engine, Exhaust, Bolt-Ons 14 04-03-2015 10:17 AM
WTB:Headers and Overpipe/Frontpipe MrTranxD Engine, Exhaust, Bolt-Ons 0 10-30-2013 11:38 AM
