Drives: 2013 MY14 Toyota gts86 Turbo
Hi guys as the thread title describes, this thread will be helpful to those who are interested in knowing just because and also for others who are planning to perform the same as myself.
I’m building my IAG Stage 1 12.5:1 CP rated to 550HP on my Manual 2013 Toyota gts86. I have the following: Have also attached an image of further parts that have been installed. Tuned through Ecutek RaceRom Upgrade, no dynotune. Garret Gtx2860RS (good for 360HP) Aeroflow Turbo Blanket Turbosmart IWG-75 Turbosmart Actuator GT28/60 7 Turbosmart BOV Plumb Black AEM Boost solenoid, used to run Turbosmart WG Tee K&N Pod Filter Direct Clutch Stage 2 Lightweight flywheel with the clutch diameter custom made AEM Tru Boost Gauge 4bar map sensor Catless exhaust straight through with Invidia N1 catback and 1 Resonator Cusco catch can Ultrex Front Strut Bar Potenza tires on the back 18” GT Hussle 18x8.5 5x95 +40, stockies on front Parts I have but not fitted: 1200cc Port Injectors Parts I haven’t bought yet: Avo oil cooler Walbro or DW Fuel Pump Flex Fuel Kit I am tuned through Ecutek with MRT Performance being the master tuner.. I may have forgotten one of two things but this is what I can think of at the top of my head so I suppose well go from there. I have completed other mods but they’re aesthetic that aren’t performance supported. Can you recommend what parts will be able to handle around 500hp for my 86 reliably as i’ve got the engine for it. She’s probably pushing 250-280hp currently but don’t know for sure. For example, -fuel pump -fuel injectors -rear axle -oil cooler -upgraded intercooler -upgraded radiator? -catch can -Flex Fuel -limitations to the manual gearbox? -upgraded actuator? -upgraded bov? Can’t forget to say Thankyou in advance to all the future helpful replies. Last edited by Phoenix_gts86; 03-16-2020 at 11:52 AM. |
#2 |
Drives: 2017 Subaru BRZ
Sent from my SM-G960W using Tapatalk |
#4 |
Drives: 13 BRZ
From an engineering point of view, you should probably reconsider a running a system that goes to >90% of your maximum capability if you want reliability/longevity.
#5 |
Drives: '14 SSM BRZ Premium
^This. And keep in mind that the IAG HP ratings are for BHP, not WHP. Not sure which you are shooting for.
"To be without silver is better than to be without honour." - Norse Proverb
#6 |
Rust bucket enthusiast
It will never be reliable, but the first step is ditching e-tuning and finding a dyno tuner. get a Reimax oil pump gear as well
#7 |
poor man's evora
Drives: Turbod BRZ
I'm at 405whp on 10.5 psi e85 on my precision 5558 ball bearing turbo, full boost at 3300 rpm. I would recommend, or use the 5858.
#8 |
Drives: Q5 + BRZ + M796
As stated, gearbox for sure. Consider a CD009 swap. Maybe rear axles.
#9 |
Drives: Raven Black
Id be really impressed if you could make over 500HP reliably.
#10 |
Drives: 2017 toyota 86
Engine and trans swap.
Even fully built blocks are lucky to be “reliable” (depends on your definition of reliable) at 450whp. And even then most aren’t that reliable above 400whp. Either change your goal to around 400whp. Or engine swap. |
#11 |
What fuel will you be using?
I wouldn't call any 500+hp FA20 reliable, until proven otherwise. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (03-17-2020) |
#12 | |
@FRS Justin 710whp... I don't know what his setup is or if he would be willing to share, but I thought he has a closed deck setup. I'm thinking lower compression too, but I can't remember. I'm sure it depends on how often the car sees that 500+whp for reliability. If it was just a highway queen then maybe it would be fine with a good setup.
#13 |
Maybe someone can chime in who is a tuner, but what are the limits of knock/detonation resistance for E85 at 12.5:1 compression? Should the OP consider going with a much lower compression to make reliable power on E85?
@Pheonix_gts86 What made you stay with 12.5:1 compression? Just for reference, the new Porsche Turbo makes 640hp with a compression of 8.7:1, and it seemed to be necessary to drop compression from 9.8:1 to do it reliably on pump gas. Maybe there is a lot of wiggle room with E85, but if the effective compression gets too high then maybe that won't be reliable.
#14 |
Drives: 2014 BRZ Limited, Satin White Pearl
Lower the compression to either 9/9.5/10/10.5 to 1
Get a stronger transmission if you plan to actually use the power. You will just spin... With those tires, no grip, the power is useless. Grippier tires will strip the trans, so upgrade the transmission and get grippier tires. Again, that much power without being able to put it to the road is useless and reckless. You will want a vented hood too for heat control. Upgraded radiator and oil cooler also help a lot.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following User Says Thank You to Tonrogs For This Useful Post: | Irace86.2.0 (03-16-2020) |
| Tags |
| 500 whp, 550 whp |
| Who makes a good AOS for our cars? | D K | Engine, Exhaust, Transmission | 17 | 05-28-2014 04:24 PM |
| GReddy Scion FR-S Makes First USA Public Appearance at Cars & Coffee in Irvine, CA | Moto-P | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 01-16-2014 02:28 AM |
| How do I use A2DP conveniently and reliably? | qoncept | Electronics | Audio | NAV | Infotainment | 6 | 06-04-2013 01:35 PM |
| Got a ride in a 550hp C5 Vette...meh. | Superhatch | Other Vehicles & General Automotive Discussions | 8 | 11-06-2012 03:32 AM |
| Aftermarket hood supports | fasteddy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 14 | 10-14-2012 12:01 AM |
