#141 | |
Drives: Subaru BRZ
Today I bled the clutch and removed the clutch spring. The car is still up in the air as I have a couple of mods to install while the driveshaft it out.
#142 | |
Drives: 2014 Subaru Forester
If you are ever in the Greenville or Clemson area of SC, we should meet up. Not the biggest twins scene here. Or I'll have to make it down to GA for a track day. |
| The Following User Says Thank You to tehShirt For This Useful Post: | Code Monkey (11-25-2019) |
#143 |
Drives: 17 BRZ Series.Yellow
Just happened to stumble across your build thread. Love it!
I also have a Series.Yellow and use it primarily as a track/time trial car. I haven't done nearly the upgrades that you've done though. Great stuff! Also interested to hear about the hydraulic TOB. |
| The Following User Says Thank You to i8ur911 For This Useful Post: | Code Monkey (11-26-2019) |
#144 |
Drives: Subaru BRZ
Since the transmisison was out and the driveshaft was out, why not kill two birds with one stone and improve the rear end? To wit:
OS Giken 1.5 way, setup by CSG, backlash checked by Controlled Motors Diftech differential cover gasket Whiteline rear diff mounts KDT923 Whiteline rear subframe inserts KDT922 I also have the KDT924 bushings to install but will leave it to a shop. The car was out of commission for 6 weeks and I really want to drive it. |
#145 |
Drives: 2010 corolla
one of the coolest cars / builds on here
| The Following User Says Thank You to beltax90 For This Useful Post: | Code Monkey (12-09-2019) |
#146 |
Drives: Subaru BRZ
A note about the JDL ultra quiet FP....
The pipe itself is great quality, but the cat and gaskets are not... Installed at 20,200 miles, the cat is already rattling at 21,043... The donut gasket is shot, the OEM donut still looks great after 20,200 miles... Replaced the gasket with a Vibrant 10108G. The front gasket separated, maybe I squished it too much, but there was no note what kind of gasket it was. Looks like it could be Remflex but I am not 100 percent sure. Replaced with Remflex material I ordered off of Amazon and my craftsman workmanship. ![]() Will check in a few weeks for any leaks. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | MCTeeJ (12-11-2019) |
#147 |
Drives: Subaru BRZ
Was planning to update this thread with my impressions of the OS Giken and hydraulic TOB but got a check engine light a week before heading to Road Atlanta. Codes P119F and P219A came up and my first thought was either my hand-made gasket failed or knowing my shit luck valves will need to be adjusted.
Upon poking around, I noticed my ACE header is cracked around one runner, taking it tomorrow to be welded. |
#148 |
Drives: Subaru BRZ
Waiting for the header to be fixed, I installed a REAL leather steering wheel and a 2018 tS steering wheel trim.
| The Following User Says Thank You to Code Monkey For This Useful Post: | weederr33 (02-28-2020) |
#149 |
Drives: Subaru BRZ
Got the header fixed and the check engine light codes are gone!
The runner that was cracked on the inside is in the 2nd picture. All the other runners got reinforced as in the 4th picture. There was also a crack forming on the outside on the other side, so that got fixed too, 3rd picture. The header/overpipe gasket was shot, a new set of studs and gaskets went it. Finally, installed an STi flexible v-bar I scored on the forum a couple months ago. |
#150 |
Nice choice on the steering wheel, I had mine done with custom stitch color as well. Did yours center perfectly?
Any clue why the header broke? I haven't seen another Ace on here with that issue. |
| The Following User Says Thank You to tehShirt For This Useful Post: | Code Monkey (03-14-2020) |
#151 | |
Drives: Subaru BRZ
I think it is just slightly off center, but not enough to bother me. I know I have it aligned perfectly with the clock spring and looking at the splines I think one over would result in a more crooked wheel.
But in general, I break things. I broke many OEM and aftermarket parts on different platforms. My wife said I should test parts for car and parts manufacturers. And stop breaking her wine glasses.
#152 | |
Drives: 2017 BRZ (Sold), 2023 GR86
| The Following User Says Thank You to mistople For This Useful Post: | Code Monkey (03-14-2020) |
#153 |
Drives: 2013 frs red
| The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post: | Code Monkey (03-14-2020), mistople (03-14-2020) |
#154 |
| Berzerk's 2017 CWP 'Slow and Steady' Build Thread | Berzerk | Member's Car Journals | 12 | 07-24-2017 05:57 PM |
| Rodie's slow '13 FR-S build | rodie | Member's Car Journals | 0 | 06-14-2015 09:05 PM |
| Slow Progression FRS Build | dgerny | Member's Car Journals | 1 | 04-15-2014 07:48 PM |
| Tkalz slow build! | Tkalz | Member's Car Journals | 15 | 10-13-2013 06:35 PM |
| Slow Build by Jooks | jooks | Member's Car Journals | 4 | 07-03-2013 11:53 PM |
