Old 03-13-2020, 09:18 PM   #1
Infinity
Drives: 2016 Scion FR-S
30K Service: Clutch Bleed?
I just called the dealer about the 30K scheduled service and they want to bleed the clutch for like $130. I have read several threads on the 30k service and none mention this. I thought the 30k service was going to be basically just oil/filter change, brake fluid, air filter, and cabin filter.
The dealer also wants to do some fuel and oil additives for like $50 and $100 which seems like way too much.
Is the clutch bleed part of the 30k service? The manual just says inspect clutch fluid at 30k. Has anyone else had the dealer suggest this as part of the 30k service? At what mileage do you typically need to bleed the clutch and change the clutch fluid?
Infinity is offline   Reply With Quote
Old 03-13-2020, 10:12 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What da funk $130 for that? Is that before or after a hand job?
Cause that's the only way I'll pay that much.
I would tell them politely to fist their butt hole.
Honestly if you want to pay that much I would go to any quickly lube place, at lest you'll get an oil change, all the fluids toped off, and/or a cheap interior vacuum.
The Following User Says Thank You to Mr.ac For This Useful Post:
0x56 (04-22-2020)
Old 03-13-2020, 11:05 PM   #3
Decep
Drives: 2013 FR-S Series 10
In general, never do these services. Just bring your car in for your fluid changes and major items (spark plugs at 60k come to mind).
Bleeding the clutch is probably not necessary unless your slave cylinder has leaked at some point. If you want just pull out the old fluid with a syringe/baster and put new fluid in and call it a day.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
Infinity (03-13-2020)
Old 03-13-2020, 11:17 PM   #4
qqzj
Drives: MDX, Camry
It's a good idea to bleed it. But you can do it yourself super easy. No need to pay dealer for it. In fact, you can combine it with brake service and one big bottle brake fluid will be enough for both.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
Old 03-13-2020, 11:21 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
$130 doesn't sound too bad to me. i can reasonably see $85 for labor and $45 for shop materials.
i haven't met many people or companies that work for free.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
0x56 (04-22-2020), mrg666 (03-14-2020)
Clutch fluid won't bleed. ML Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-19-2018 09:35 AM
DIY : How to bleed your brakes justinco DIY (Do-It-Yourself) Guides 4 09-05-2017 03:40 PM
Valve/nipple (bleed?) next to clutch line? BRZyJ Engine, Exhaust, Transmission 2 06-14-2017 01:28 AM
Clutch grinding. Need service recommendation rhythmM Southern California 6 04-07-2016 07:16 AM
OAKOS/DVR Service Specials! Clutch Install $399! Timing Belt $199! St. Heights, MI OAKOS Automotive Great Lakes 78 05-14-2015 01:10 PM
