go_a_way1, MisterSheep
Old 03-11-2020, 01:59 PM   #21617
Originally Posted by Blighty View Post
Oh, and yeah I know boost can do significantly more instantly and for chump change, but the engine was designed for NA - and I dont know how many engines we will be able to say that for anymore.
Apart from very expensive sports cars, practically everyone is moving to boost, including the next 86. I'm ok with getting just 40hp of extra NA power, slowly over time, even if it costs me a for bit.
Fun fact - this is the most powerful production NA boxer 4 ever made (for all that we lambaste it, that's actually impressive given the emissions requirements). To be honest I'm not sure if that will ever be broken because of the way the world is going.
Betcha' a beer there is never a FI 86.
wolffbite (03-11-2020)
Old 03-11-2020, 02:23 PM   #21618
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I will NOT take that bet lol
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
Tcoat (03-11-2020)
Old 03-11-2020, 06:23 PM   #21619
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Switched over to E85... Hope it starts today! 43F out right now. I looked at the tune in RR and there are 4 more tables than all the tutorials show, plus it's in C not F, so I was hesitant to change anything yet.
Weigaldo is offline   Reply With Quote
The Following User Says Thank You to Weigaldo For This Useful Post:
SuperTom (03-11-2020)
Old 03-11-2020, 10:08 PM   #21620
new2subaru
Weight Weenie
Drives: 15 FR-S
Cleaning the engine bay. I have a bunch of parts removed and cleaned and did the timing cover so far.
Somoniz aluminum wheel cleaner works great but smells like horrible!! I'll mask up next time.
The Following 3 Users Say Thank You to new2subaru For This Useful Post:
Leonardo (03-11-2020), MJones_RB (03-12-2020), SuperTom (03-11-2020)
Old 03-12-2020, 02:10 PM   #21621
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Wow. Not all heroes wear capes.
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
new2subaru (03-12-2020)
Old 03-12-2020, 10:13 PM   #21622
new2subaru
Weight Weenie
Drives: 15 FR-S
It doesn't really take much to clean it. I like taking things apart to see what's what.
I'm also doing so polishing while I'm in there and may do some wiring tucking. It'll give me an idea on what I want to do next winter. The combined engine/body harness drives me crazy...
The Following User Says Thank You to new2subaru For This Useful Post:
MJones_RB (03-13-2020)
Old 03-14-2020, 02:06 PM   #21623
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Put some sound deadening in the trunk - I was chasing a rattle coming from the rear and started removing elements to eliminate them as potential sources. Didn't find the rattle (think it's coming from the outside ), but thought I might as well put some insulation before putting everything back together.
alex87f is offline   Reply With Quote
Old 03-14-2020, 02:09 PM   #21624
jflogerzi
jflogerzi's Avatar
I am curious to hear your feedback on how much of a difference sound levels are vs stock
2013 Series 10 FRS #553
Old 03-14-2020, 09:44 PM   #21625
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Installed a perrin 22mm front sway bar, racerx endlinks, and spc camber bolts
[ame]https://www.youtube.com/watch?v=VoF0-OTiojw[/ame]
The Following User Says Thank You to Breadman For This Useful Post:
MJones_RB (03-16-2020)
Old 03-15-2020, 10:55 PM   #21626
dnieves
Drives: FR-S 10 Series
Drove from Long Island NY to Delaware and back yesterday (nothing more fun than a long road trip in the FR-S). Take a quick trip today then on the way back upon turning on the ignition I get CEL and Slip lights (never had that before). After inconclusive OBD scanning (P0018 & C1201) and research I dis/reconnected the battery to see if it comes back.
Car is completely stock and 44k mi.
Fingers crossed.
Inconclusive because the P0018 is indicative of a crankshaft problem and C1201 ECS malfunction. On this site I've read threads about this and changing out the ECS (which didn't work), engine work, slip sensor replacement, and etc. I don't want to spend $150 for a Toyota tech's best guess.
dnieves is offline   Reply With Quote
The Following User Says Thank You to dnieves For This Useful Post:
humfrz (03-16-2020)
Old 03-16-2020, 08:12 PM   #21627
MJones_RB
MJones_RB's Avatar
Blacked out all of the silver painted trim.
The Following 4 Users Say Thank You to MJones_RB For This Useful Post:
beltax90 (03-16-2020), humfrz (03-16-2020), RToyo86 (03-20-2020), StraightOuttaCanadaEh (03-16-2020)
Old 03-16-2020, 10:30 PM   #21628
Well, that may be better (cheaper) than just throwing parts at it -
Old 03-16-2020, 10:33 PM   #21629
If the trim would have come from the factory blacked out, would you have painted it silver?
MJones_RB (03-17-2020)
Old 03-16-2020, 11:44 PM   #21630
dnieves
From what I read here that's what the Toyota techs do: change the crankshaft position sensor then the error may/may not go away. Then when it returns they change the ECU. Then after that they take your camshaft apart charging you $$ every step along the way until you get a $6k bill at the end.
What a pain, this car has been trouble free (minus crickets/condensation in the tail lights/leaky cam plate) but being babied and with so few miles I didn't expect a CEL that keeps coming back.
With zero warranty left would I have better luck at a Subaru dealership? These engines aren't the servicing nightmare of a rotary but I don't want to finance guesses.
humfrz (03-17-2020)
